piaffepony
- Joined
- Feb 27, 2017
- Messages
- 127
- Location
- Ft. Worth
- Tractor
- JD 5055D, David Brown1212, NH LS170, JD Gator 850D
I know I posted about a load handler for my flat bed for unloading hay/shavings and what not. I also posted about my fabric building damage and have a lot of super heavy duty tarp material hanging around.
With all of rain we’ve had since the big storm, I need gravel and arena sand. Sooo yeah... I’m going to haul it myself because it’s not like I’m giving many lessons until my damage is repaired.
The consensus has been that I can haul approximately 2 cubic yards on my truck. I’m in the process of making my side rails now... but I still need unloading solutions.
Y’all mentioned pulling loads off with tractor. I did this with a much smaller load of pea gravel and a old regular cheapy tarp and it did work... once.. all the grommets ripped out and what not, which I kind of expected. I was in a hurry and didn’t take the time to brainstorm a stronger solution. The torn tarp pieces from my building are plenty big enough and much stronger.
Any ideas on how to rig it up so I can pull it off with the tractor evenly and make sure most of it stays on the tarp while dragging it off without ripping it up too much? I need probably 20 cu yards of sand (thank goodness it’s only 5 miles to the quarry!)
Would installing grommets to tie to a metal pipe work? To me that seems too flimsy.
Surely one of you geniuses have a DIY solution to my problem?
