Flail Mower Bearing Clamp Bolt Mott 72Flail.
   / Bearing Clamp Bolt Mott 72Flail. #1
EdwardB
Michigan
JD 4410
I am having problems with the bearing clamp bolt for the main shaft on my Mott 72. It wants to loosen up and has actually fallen out once. I tried blue thread locker, but it did not work. Maybe I didn't use enough. There are no unexpected vibrations at 540 operating speed. Any suggestions?
   / Bearing Clamp Bolt Mott 72Flail. #2
Any way you can drill the head and safety wire it?..................Mike
That is a great idea! Unfortunately, the bolt itself is screwed into the shaft and spins with the shaft when running (unless something is seriously amiss here).
I'll snap some pictures tonight.
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
E-Z Trail 680 Adjustable Head Cart (A50514)
E-Z Trail 680...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
