I cracked my valve cover...
   / I cracked my valve cover... #1
RADIATION
Member
Kioti LK3054
Hello All,
I'm new to tractors. I bought a kioti lk3054 with a head gasket problem. HG had been replaced but tractor still ran like garbage and bubbled radiator. I tore the head off and they head used the wrong gasket. I put the right one on and put it back together using the LK30 manual i got from this forum. Everything was great and running great until i decided to follow the manual and retorque the gasket. I retorqued and was putting everything back together and decided i better torque the valve cover to be precise. I ignored my gut and heard a faint tink... took the cover off again and 2 out of 3 bolt holes have a faint 3 spider crack... :mad:
I put it back together and just snugged the bolts. I ran it up to normal temp and there's no oil coming out of bottom of cover or anywhere else for that matter. I'd still like to replace it. Does anyone have one?
   / I cracked my valve cover... #2
I might have one. We need to verify it is the same. I have the original engine from my 2554 that slung a rod. The head is fine but not sure the difference between the two engines. Maybe we could check part numbers. I will check it out.
What version 3054 do you have?
The part number for the one I have is E5500-14505. It is the old style.
This is the one i have, thank you for your response!
   / I cracked my valve cover... #4
I believe you might be in luck. Can you read the plate on your engine? Is it a TD1300 or TD1400?
   / I cracked my valve cover... #5
Also mine is pre law suit, so it is blue in color if that matters to you.
   / I cracked my valve cover... #6
Here is a picture.
Yes sir that's the one, and i don't know where said plate is on the engine, I've hunted it over and only found an embossed 1395cc.
Here Is a picture of mine. How much are you asking sir?
   / I cracked my valve cover... #8
I will make you a deal. PM me your address and I will take it off, then send it to you. Once you get it fixed post a picture and we will call it even. If you do not use it, send it back so it will be available for whoever else might need it. Does that sound like a deal?
PM sent! Thank you so much!
   / I cracked my valve cover... #10
My pleasure and welcome to TBN!
Payment Terms (MUST READ) (A50775)
Payment Terms...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
2017 Chevrolet Malibu Sedan (A50324)
2017 Chevrolet...
HYSTER H50FT FORKLIFT (A52472)
HYSTER H50FT...
2023 FORD F-250 SUPER DUTY (A52472)
2023 FORD F-250...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
