Let's see your metal buildings
   / Let's see your metal buildings #51
Need to get a metal building/pole barn at my place. Everywhere I've gotten quotes from is just insanely expensive. Have to build for a heavy snow load
   / Let's see your metal buildings #52
I'm starting to lean towards wood with a metal roof. Mainly because I'm figuring two story on a steep slope with drive in access on both levels. And I think I want to do the electrical, plumbing, and inside finishing myself and wood walls should make it much easier for DIY.
I will be around a lot of evergreen trees and think a metal roof will be so much easier to maintain.
Metal roof equates to NOISE in the rain !
My metal building with a sheet insulation, worthless, is very noisy when it rains.
To have it fully insulated now, I have been thinking on it, is going to be pricey, a lot of stuff in the way !
With wood, I can put in insulation either by the roll as time/money permits or can have the whole job done in either fiberglass or foam.
AND as I said before I would have been more confortable running standard Romex wiring and attaching shelves, cabinets, even just bracing would have been easier. With a metal building you are limited in the areas you can attach things, there are only so many main beams to attach to. To mount a Hardware Bin Holder (?), I had to run 2x4 from the first Side Bracing to the floor, then drill and attach it to these braces... THEN I could attach the Hardware Bin Holder. Nothing is easy in a metal building.
So, to repeat myself and at my age that happens more than I want to admit, nothing is easy.
Also, depending where you are building, consider building the walls with 2x6's, more insulation, and heavier than spec'd floor beams, for same reason, harder to go back to add more strips of wood to add more insulation than to just build it, and the cost of 2x4s vs 2x6s isn't that much when you are building.
Ltr
   / Let's see your metal buildings #53
Ltr
Yep, agreed that 2x6s and well insulated is the way to go for at around here in the PNW. I plan to heat this shop. My garage/shop I have now is not heated. This will be a luxury and since I plan to spend a lot more time in my 'dog house' once I retire, I want to do it right.
   / Let's see your metal buildings #54
Then put in hydronic radiant floor heat.
   / Let's see your metal buildings #55
About all the comments about having to reinforce the tin walls and not having any place to hang things. My metal building is a 40 x 60 clear span with horizontal "C" purlins at the floor, 4' up, and 8' up so I can attach plywood (or OSB) to it all around the building and I can put anything anywhere. I run exposed conduit and air-lines above the plywood and have conduit down behind the plywood to outlets. It's always best to plan ahead so things can be embedded in the walls and floor. I have conduits that run under the slab from one side to the other, but didn't think about putting an outlet near the overhead doors, so those are surface mounted with exposed conduit.
Also, in addition to rain noise, there is also oil-canning noise. Both of these are much less with spray foam.
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A55218)
2018 Link-Belt LBX...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
