John Deere 1550 TerrainCut 4 wheel drive with 7 iron deck
   / John Deere 1550 TerrainCut 4 wheel drive with 7 iron deck #1
lguthrie
1550 Terrain Cut
While mowing as you accelerate the lawn mower starts jerking. This happens when it is under strain and either in 2 or 4 wheel drive. You have to almost stop for it to stop jerking. it seems to be ok going very slow but at moderate speed it is not smooth.
   / John Deere 1550 TerrainCut 4 wheel drive with 7 iron deck #2
:welcome: to TBN
Could use more information about the history as you know it. Age, maintenance, your experience with it over the years, etc.
Have dealer nearby, have service tech manual, ??
   / John Deere 1550 TerrainCut 4 wheel drive with 7 iron deck #3
Welcome to TBN.
Does the problem you are experiencing happen on level ground, or going up or down a hill?
Richard
Welcome to TBN.
Richard
This mower is only a year old. It happens on any type of ground. When you are mowing at a slow rate and increase the speed, is the time it does it most. It just starts to jerk and jump until you have to really slow down. It almost feels like your foot is bouncing on the gas petal.
   / John Deere 1550 TerrainCut 4 wheel drive with 7 iron deck #5
Did it accelerate smoothly up until recently? Fluid level correct? On my 1570 I need to run the engine for 30 seconds before shutting it off to check the hydro fluid level.
With the unit turned off I would remove the service cover and watch the linkage while you press the forward/backward pedals. Maybe there is something wedged in there affecting the movement. The pedal and linkage movement should be smooth.
dsb
2012 FORD F650 ROUSTABOUT (A52472)
2012 FORD F650...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A51572)
2008 Sterling...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
