Popular mythconceptions
   / Popular mythconceptions #431
The rubber was porous and often contained carbon
That's enough right there; rubber with carbon in it can conduct electricity (see also, "why do cars get hit by lightning when they're riding on rubber?" - note that some modern tires actually have too little carbon in them for conductivity so have an "antenna strip" to help this) and so there can be leakage.
   / Popular mythconceptions #433
I am pretty sure you should not drop them from a 4 foot elevation to the floor.......
:D
   / Popular mythconceptions #434
Another one:
It is safer to pull hard with a chain than a strap or cable, because if it breaks, it will fall harmlessly to the ground instead of snapping back.
Bruce
It is safest to pull hard with something that doesn't stretch. When something stretches it is storing energy like a spring and if it breaks that energy will release as a whip.
   / Popular mythconceptions #438
You just can't give up, can you? According to my link/quote they both caused problems. Also, even a modern battery will leach if there's enough dirt and grime on it, and the moist environment which many concrete floors provide will enhance that.
So adding a piece of plywood or some other thin spacer cleans the dirt off and prevents moisture? I’ll have to remember that one.
   / Popular mythconceptions #439
So adding a piece of plywood or some other thin spacer cleans the dirt off and prevents moisture? I値l have to remember that one.
Or just clean the **** thing off...and that's also a good idea if the battery is in your vehicle.
Hyster H225E Forklift (A47477)
Hyster H225E...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
UNUSED LANDHERO LDH-T460 STAND ON SKID STEER (A54756)
UNUSED LANDHERO...
