Grease gun coupleer adjustment??
   / Grease gun coupleer adjustment?? #1
Wilburn Cox
Stephenville Texas
Kubota B7100
I have a standard lever action grease gun. The grease coupler needed replacement. I bought a new lock n load (not lock and lube) coupler from tractor supply and the new one will not go on the grease fittings. I called the maker, Legacymfg.com and was told the coupler could be adjusted by turning the knurled portion while holding the other end by a wrench. The knurled portion will not budge. I tried pliers and vice grips and it will not turn.
Any suggestions will be appreciated and as always have a great day.
Wilburn "Red" Cox
Wilburn "Red" Cox
After reading some info on TBN I went back to the ship. I finally got the coupler to adjust by using vice grips on the knurled portion and a lot of strength to turn. I am 78 years old and have to admit I never knew the couplers could be adjusted. I am thankful I am still able to learn and try new things. thanks to all and God bless
   / Grease gun coupleer adjustment?? #3
I never tighten mine down, so I can adjust it easily by hand as needed. They are similar to adjusting a drill chuck. You will want it just snug enough to fit on the zerk without popping off under pressure.
Thanks Ford850, I had the new coupler for several months but never put it on the gun until last week. I Needed to grease bearings on my lawn mower so installed the new coupler on the gun. It would not go over the head of the zerk so took it off and put the old one back on. I am glad I finally broke the adjustable part of the new one loose. Live an learn. Have a great day an as always be careful
   / Grease gun coupleer adjustment?? #5
Did you actuate the LnL coupler before you tried to put it on the zerk? You do know you can't just "stick it on" like a regular coupler right?
   / Grease gun coupleer adjustment?? #6
He bought just a regular coupler, not a LnL.
" I bought a new lock n load (not lock and lube) coupler...."
   / Grease gun coupleer adjustment?? #7
   / Grease gun coupleer adjustment?? #8
Thanks to @Wilburn Cox for introducing this thread, and to Ford850 for the explanation; never knew they were adjustable
It takes several hundred pumps to grease my walk-behind, and with how easily it popped off it took one hand pushing on the coupler just to get some grease in. It wasted a lot, took a lot of clean-up, and way too much time to get done.
I saw the knurled piece on mine had no gap to the body - couldn't see threads - and would not loosen by hand. But it came loose in a vice, with a lot of force. Wilburn Cox, at 73, I'm not far behind you! ;)
Since it wouldn't hold on a zerk though fully tightened, I took it apart. It's a 3-jaw type, and took a lot of fiddling to get it back together. During those attempts, I noticed one end of each of the jaws had a shiny spot. Not like noticeable wear, but I flipped them 180 to re-assemble anyway. That made all the difference.
When it was back together, I thought I had messed something up because I couldn't close the gap at the threads - the jaws were as far closed as they'd go. But, they could be opened farther, and easily locked on a zerk - tight enough so it couldn't be popped off, and the knurled piece rotates easily for adjustment, like Ford850 said.
Apparently there is so much mechanical advantage in the assembly that those little shiny spots were enough wear to reduce adjustment range. So if yours has similar symptoms and you can't readily buy the "lock'n'whatevers", give this a try.
   / Grease gun coupleer adjustment?? #9
Never tried a LocknLoad, but buying a LocknLube fitting was the best thing I’ve ever done. I don’t dread greasing anymore.
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
STORAGE FEES (A51222)
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2007 INTERNATIONAL SF625 BUCKET TRUCK (A50854)
2007 INTERNATIONAL...
2017 DRAGON 48' ROLL OFF TRAILER (A50854)
2017 DRAGON 48'...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
