Battery powered or lever pump action for back pack sprayer
   / Battery powered or lever pump action for back pack sprayer #1
Wilburn Cox
Stephenville Texas
Kubota B7100
Hello everyone. I have 4 acres with a house, barn, shop and well house. I have a 15 gallon Fimco spray rig which I pull with my mower. I am considering a 4 gallon back pack sprayer for lesser amount of spraying around the place. Question; what are thoughts about battery operated or lever pump action?
I did some research and Chapin sprayers seem to be made well.
thanks in advance and as always stay safe.
Wilburn "Red" Cox Stephenville tx
   / Battery powered or lever pump action for back pack sprayer #2
I have a Solo piston pump 4gal backpack sprayer. I bought it from the neighbor used when they had a sale and it has been flawless for about 20 years now. Working the lever is natural and is easy to operate.
   / Battery powered or lever pump action for back pack sprayer #3
With your 15 gallon rig available for larger area's, I wouldn't want to have to fool with and maintain batteries just for some spot work.
   / Battery powered or lever pump action for back pack sprayer #4
I have the 4 gallon Chapin 20v that I mount on my golf cart usually. Only use on my back when spraying trees. I bought it because I already had a bunch of the correct 20v batteries. Would not want to be without it. Sprays forever on a charge. No way would I hand pump again.
   / Battery powered or lever pump action for back pack sprayer #5
I had a 4 gallon pump type backpack sprayer awhile ago. It worked fine, but it wore me out after awhile and I just never used it again. For my big spraying needs, I have a sprayer mounted on a trailer that I use for my fence lines, and for my small areas, I use a 1 gallon sprayer. It doesn't wear me out and I either do refill it and keep using it, or I just do a gallon and then another gallon the next day. After a few years of being in they way and starting to fall apart, I threw away the 4 gallon backpack sprayer.
   / Battery powered or lever pump action for back pack sprayer #6
   / Battery powered or lever pump action for back pack sprayer #7
+1 So do I. A couple stokes on the pump handle is all it takes. I'm 70 and I don't find it at all exerting.
2006 International 4400 LP Ambulance (A50323)
2006 International...
INGERSOLL RAND G25 GENERATOR (A50854)
INGERSOLL RAND G25...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
2013 MACK CXU (A50854)
2012 KENWORTH T800(INOPERABLE) (A50854)
2012 KENWORTH...
