hydraulic lift cylinder rings
   / hydraulic lift cylinder rings #1
Lincolnshire, UK
Iseki TX1500F 4wd
can anybody on here got or can point me in the right direction for a set of the 3 point hydraulic lift ram rings to fit a TX1500f just done a couple of hours on the internet and found jack every other tractor but a iseki tx
   / hydraulic lift cylinder rings #2
The Bolens G172 is the same machine. Have you tried finding the part from a Bolens supplier? I also wonder if you just cant find the OEM part, can you take the piston seal, take good measurements and find a match through a hydraulic parts supplier?
Hi Darryl thanks i didn't think of that Bolens G172, do you know if its just that model number or through the G172 - G range
i can't measure it as its still in working its just that it needs changing because it slowly creeps down overnight so i thought i would get a set now and on the next five minutes i get i would have everything ready to change it
   / hydraulic lift cylinder rings #4
I cant say for sure if the G152/G154 ( Iseki TX1300) seal is the same as the G172/G174 seal but I would bet my last dollar that the G172 ( 2 wheel drive) and G174 (FWD) use the same seal. Here is a link to another forum discussing a G174 3 point lift issue. The OP says the G174 ( iseki TX1500) and the Iseki TX2160 share a lot of crossover parts. https://www.tractorforum.com/threads/bolens-g174-hydraulic-lift-problem.24600/ A little more searching indicates the White Field Boss 16 appears to share a lot of parts with those Iseki and Bolens models. White Field Boss 16 parts diagrams and part numbers are available to view at https://apb.agcocorp.com/ -- enter site as "Guest User". (You may or may not be able to view this site since you are in the UK)
Here are part numbers for the 3 seals on the FB16's 3 point piston.
33-0129011 1 RING - BACK-UP
33-0128872 1 O-RING
33-0042331 1 O-RING
Who knows if any of this will match your TX, I'm just try to give you some options.
are thank you so mine is a G174 and with that information i found this and it indicates to me that a whole range of tractors have the same piston seal but no leather backing washer tho
33-0128872 1 O-RING
33-0042331 1 O-RING
the site will only let me find a dealer in the uk for massey ferguson tractors must be a big company tho got a few dealers over here
   / hydraulic lift cylinder rings #7
Hi Second (sorry don't know your name), i was in contact with this Yenibiz company.
I can order those rings (i need two sets myself actually), and shipping to Holland will take total of 5.45 euro.
The price for rings are
- o-ring: 6 euro
- backup ring: 11.23 euro
So i can order this, we will split the shipment charges.
What do you think?
thx
M.
- o-ring: 6 euro
What do you think?
thx
M.
Hi marcel that would be great yes I have 2 sets as well all ways good to have a spare set
Best regards terry
   / hydraulic lift cylinder rings #9
Ok no problem.
Just one remark: i hope you are not in a hurry. I am travelling, cannot order before friday. Then the stuff has to be sent
- from Belgium to Holland
- from Holland to Poland
- from Poland to UK
I guess/think the whole thing will take 2 weeks. Is that a problem?
Ok no problem.
- from Poland to UK
No worries there I been looking for a while now so a few more weeks isn稚 going to corse any problems I am just pleased I will be getting it fixed many thanks to you sir
Best regards terry
Year: 2016 Make: Ford Model: Transit Van Vehicle Type: Van Mileage: 240,650 Plate: Body Type: 4 D... (A51692)
Year: 2016 Make...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A53426)
2013 FREIGHTLINER...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
2014 KENWORTH T800 KILL TRUCK (A53843)
2014 KENWORTH T800...
2019 John Deere 5090R Tractor (A52384)
2019 John Deere...
