Should the blow back hose be filled with fuel?
   / Should the blow back hose be filled with fuel? #1
Mrez
Spring hill, fl
96 ford 3930
I am removing the fuel injection pump on my 1995 3930 and when I removed the plastic blow back hose it was filled with 1/2-3/4 gallon of fuel.
I don't understand this? Does it mean my injectors are bad? I was told my pump was bad because I am not getting fuel to the injector lines.
What is the purpose of this blow back line?
   / Should the blow back hose be filled with fuel? #2
Not sure what u mean.. theres no such thing as a "blow-back hose"..
The correct terminology will help determine what you mean..
Do u mean the injector return line.?? The pipe connected to the top of the injector that links all of them together.??
   / Should the blow back hose be filled with fuel? #3
OP, the return line goes back to the fuel tank and yes it should have fuel in it. If you're injectors aren't getting fuel the control rack inside the pump could be stuck.
If you unscrew the lines from the injectors and crank the engine you should get fuel coming from those lines.
   / Should the blow back hose be filled with fuel? #4
In my experience, if the tank is filled to a point above where the return line attaches the the tank, the tank will drain itself via the return line when removed, until the fuel gets below the return line.
   / Should the blow back hose be filled with fuel? #5
The return lines I have seen go into the very top of the tank a bit above the full fuel level..
   / Should the blow back hose be filled with fuel? #6
Traditionally I have, too, but on my ‘94 5030, it’s down just enough to allow some drain back if the tank is full. I only know this because I swapped injectors with a tank full of fuel, on a brand new cement floor. It was a mess.
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
2018 CATERPILLAR 318FL EXCAVATOR (A51246)
2018 CATERPILLAR...
John Deere 772-A Grader (A52384)
John Deere 772-A...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
