Engage PTO at high idle or full throttle?
   / Engage PTO at high idle or full throttle? #1
Vigilant
On an X500, will I reduce wear and tear on the PTO clutch if I engage it at high idle instead of full throttle, or is full throttle better?
Thanks in advance.
   / Engage PTO at high idle or full throttle? #2
I only ever engage an implement at just enough RPM not to stall the engine, then increase.
Same here. I was just curious because some folks claim you should engage at full throttle. That's why I posed the question. Thanks.
That's what I thought. Thanks.
   / Engage PTO at high idle or full throttle? #7
Kind of the same with a manual car, unless you are into drag racing and breaking things.
   / Engage PTO at high idle or full throttle? #8
On my X540 I engage the deck just above idle by applying the choke about halfway first. This keeps the engine from stalling and prevents the jerk and belts squealing. Prior to this had to be close to full throttle or the engine would stall.
Good idea. I'll give that a try. Thanks.
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2007 INGERSOLL RAND  G80 GENERATOR (A52472)
2007 INGERSOLL...
2020 JOHN DEERE 7R210 LOT NUMBER 47 (A53084)
2020 JOHN DEERE...
40ft High Cube Shipping Container (A51573)
40ft High Cube...
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
