Engage PTO at high idle or full throttle?
   / Engage PTO at high idle or full throttle? #1
Vigilant
On an X500, will I reduce wear and tear on the PTO clutch if I engage it at high idle instead of full throttle, or is full throttle better?
Thanks in advance.
   / Engage PTO at high idle or full throttle? #2
I only ever engage an implement at just enough RPM not to stall the engine, then increase.
Same here. I was just curious because some folks claim you should engage at full throttle. That's why I posed the question. Thanks.
That's what I thought. Thanks.
   / Engage PTO at high idle or full throttle? #7
Kind of the same with a manual car, unless you are into drag racing and breaking things.
   / Engage PTO at high idle or full throttle? #8
On my X540 I engage the deck just above idle by applying the choke about halfway first. This keeps the engine from stalling and prevents the jerk and belts squealing. Prior to this had to be close to full throttle or the engine would stall.
Good idea. I'll give that a try. Thanks.
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2022 TAKEUCHI TL12R2 SKID STEER (A51246)
2022 TAKEUCHI...
2023 Utility Cargo Trailer (A51572)
2023 Utility Cargo...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A53472)
New Lewis Brothers...
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
