I let my X500 idle for about a minute after it starts, but when I'm finished mowing, instead of just parking it in the garage, I let it sit outside and blow down while I trim. We already talked about engaging the PTO. As I said, I engage my PTO at just above idle, then speed up gradually to full throttle. I will take the advice of another member and try idling it down even more and half-choking before I engage. I do my best not to ever turn the steering wheel unless the mower is rolling to make it easier on the front end and steering. Every 200 hours or so, I add a bottle of Techron to a 7 gallon gas can before filling. Of course, I only buy non ethanol gas. I change the oil every Spring with Mobil 1 Extended Performance 10W30 and have everything greased. I have the blades sharpened every season (about 50 hours) and the belts checked. A sharp set of blades means a cooler engine. Transmission is serviced every 200 hours or so.
Can anyone else share some tips to reduce wear and tear? Thanks in advance.
