4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,770
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
So my truck needed a master cylinder put on the clutch. I’ve heard horror stories of bleeding a clutch so I decided to let a shop do it. The quoted 1.5 hours at $80 an hour. I did want to pay that so I did it myself. It took maybe an hour to put it on and that’s with a lot of screwing around with the roll pin. They make a lot better tools than a punch and hammer that I had to do it. Next problem was bleeding it. Once I determined that pumping the clutch and or using the bleeder screw was hopeless and moved on to vacuum bleeding it went pretty easy. Knowing what I know now ( which the professional shop should already know ) and having the proper tools for the job ( which the professional shop should already have) I could easily install and bleed it in 30 minutes. Ok moving truck inside shop, installing cylinder, removing truck from shop, and writing up ticket maybe an hour. I remember thinking the same thing when I split my tractor. I don’t remember what the shop manual said but given a few attempts I could do it in a day or so.
