New member, hunting help on John Deere 4300 sst 3 speed.
   / New member, hunting help on John Deere 4300 sst 3 speed. #1
Sgtjacman
John deere 4300 sst 3 speed
Hi, my name is Pat and I inherited a 4300 john deere 3 speed sst from my father. I remember splitting the tractor with him to repair the range shifter fork as it had broken and less than 500 hrs. Now I have a new problem, 996 hrs. I was dragging the driveway the other day and after about 3 trips back and forth from end to end (about 1000ft.) I went to turn around and went to reverse backed up and low and behold it's stuck in reverse. So far I've driven all over in reverse trying to get it out, jacked up each rear tire and while moving the tire back and forth still could not get it out of reverse. Any and all help appreciated. I have a mechanical background and I'm not scared to tackle any job. But my service knowledge of this tractor is limited to preventative maint. And when my dad and I split the tractor.
   / New member, hunting help on John Deere 4300 sst 3 speed. #2
:welcome:
Welcome to the forum! I'm going to move this thread over to our John Deere section to see if we can find you some help.
Thank you CatheineTBN
   / New member, hunting help on John Deere 4300 sst 3 speed. #4
Nothing gained by making more duplicate posts.. Difficult to know which of the three to respond to now.
   / New member, hunting help on John Deere 4300 sst 3 speed. #5
Have you checked the forward/reverse pedals' linkages? Do the pedals move up/down normally or does the reverse pedal stay down?
   / New member, hunting help on John Deere 4300 sst 3 speed. #6
rekees4300
I'm thinking this is the SyncShift tranny.. with forward / reverse within each range.. suspect linkage to the hand lever would be suspect. Maybe the OP will add more info.
TractorData.com John Deere 43 tractor transmission information
Exactly what I was thinking beenthere,
I just dont see anything external s I am going to drain oil and remove the cover where the linkage goes into the side of the case and hopefully I can see and repair the problem there.
   / New member, hunting help on John Deere 4300 sst 3 speed. #8
You're correct, I had a brain cramp and confused my HST with SST. DUH :confused2:
Lol, I tend to do that alot. The older I get the worse it gets.
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
Killbros 1135 Grain Cart (A59814)
Killbros 1135...
2004 FORD F-350 XL DUALLY CREW CAB FLATBED TRUCK (A59823)
2004 FORD F-350 XL...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
2006 Chevrolet Express 3500 Cargo Van (A59230)
2006 Chevrolet...
