AR Rifles..
   / AR Rifles.. #351
And what was you're point again??
This thread was going fairly well until you decided to come in and tell me you NEVER pay for dogs and you NEVER would spend a dime training you're dogs so apparently the way I do things bothers you, Good I'm glad, and you think anyone cares, all you do is look for a thread you can start trouble in..
I bought a dog and paid to have it trained.. You don't think I should have, who cares what you think..
Once in a while you post something worth reading but it isn't often...
Can you not see the posts you have posted just in this thread alone that you're posts not only have nothing to do with the thread and they have a trolling causing trouble nature to them?
Total dip.
My point is something is only worth what someone is willing to pay.
YOU turned my post into somthing it wasn't because that's what YOU expected.
   / AR Rifles..
Finding a stray "pit bull" is no different than finding a stray young child that has no guidance Iin their life
I was pretty sure of it before this post but now, I know you're nuts...
   / AR Rifles.. #353
He's not nuts!!!! He's on a different plane is all. He's misunderstood. I've saw him say that many times!!! :)
   / AR Rifles..
At least he admits it I guess..
Pit bulls are the same as misguided children and AR's... There is something shorted to ground somewhere... Oh well, time to think about something that makes sense..:)
   / AR Rifles..
I致e got a Timney 4lb single stage. It has a very short break and it is crisp. It is quite the improvement over what most manufacturers put in rifle builds. It痴 fairly easy to install but I would recommend a KNS anti-walk pin set with any trigger upgrade since you have the pins out anyway. I have this in my .308 build. Hardest part of replacing it is putting the little set screws in on top of the first ones you tighten bc of the spring tails. Even though I love this timney trigger my next one in a future build will be a Velocity trigger. They cut the spring tails off and they are made by one of the guys who used to work for timney. Price point is better as well (based on the AR10 trigger).
If you you think you might like a 2 stage trigger then I hear really great things about LaRue.
Did some research, ordered the pin set and Velocity trigger.. That should make me happy... Thanks for pointing me in that direction..
   / AR Rifles.. #356
This is my AR15 5.56 along with my S&W 9mm M&P, I custom fitted everything in my Plano case.
   / AR Rifles.. #358
Uh.. I might be a bit late.. just got this flyer in email. But brownells has a sale on drop in AR triggers
RISE ARMAMENT at Brownells
   / AR Rifles.. #360
Let me point something out real quick. All dudes should be level-headed and courteous, in other words, gentlemen. Firearm owners, they should definitely exhibit those qualities.
I said all I had to say about AR's, so I'm gonna unsub from this thread at this point, all this back & forth with this Sigarms guy is lame.
2013 Caterpillar AP500E Asphalt Paver (A52377)
2013 Caterpillar...
23311 (A51694)
23311 (A51694)
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light (A52377)
2019 Allmand Bros...
Peterbilt 377 Semi-Truck (A55218)
Peterbilt 377...
2011 New Holland Boomer 90 MFWD Utility Tractor (A55301)
2011 New Holland...
