Parking Brake dash warning light CK 35 / 4010 hst
   / Parking Brake dash warning light CK 35 / 4010 hst #11
KIOTI CK10 Tractors do not have a Parking Brake switch. You will only see the light when the key is turned to "on".
Hope this helps,
Thanks for the reply and link ThreePoint , and Michigan Iron. I guess if I want a brake light and 4WD Light I’ll have to wire it up
myself. Appreciate all the input.
   / Parking Brake dash warning light CK 35 / 4010 hst #13
Thanks for the reply and link ThreePoint , and Michigan Iron. I guess if I want a brake light and 4WD Light I値l have to wire it up
Yes, an odd attempt at cost savings? In WV if I'm moving I'm usually going up or down so I use 4wd and parking brake regularly. If I try to drive away with the brake on it is rather obvious, I guess because it is so new...? With regular use it becomes pretty automatic so I'm not missing the light...
   / Parking Brake dash warning light CK 35 / 4010 hst #14
Dullpain:. Can you confirm if you at least have a set of connectors on your newer CK to enable you to add a switch? Then also reply if/when you decide to jumper them together to test the light to your dash.
Since the 4WD indicator discussion came up, I would like someone with a working 4wd indicator to share a photo of the switch setup and where the connector is located. This is something that I would like to get working on my DK.
Thanks
PEJ5 - I’ll check it out and reply , but will be awhile.
   / Parking Brake dash warning light CK 35 / 4010 hst #16
Do you get a warning light on your dash when you set the parking brake and tractor is running ?
There is a parking light on my CK3010 HST, but I don't ever notice it, so I end up driving with the brakes on. Sometimes I don't even see it till I'm back in the shed.
   / Parking Brake dash warning light CK 35 / 4010 hst #17
CreekFlats, very interesting. I know that Kioti offers some tractor models and features in some countries/regions, but not in others. Looks like your CK3010 HST is one example. I found it on Kioti's Australian website, but it's evidently not sold in North America. I'm wondering if the parking brake light switch on yours might fit, or be easily adapted to the North American CK3510 series. :scratchchin:
My 2018 CK35010SE HST has a parking brake light on the instrument panel that illuminates with the rest when the ignition is switched to "on", but, as Michigan Iron & Equipment posted, there is no switch installed to illuminate it when the parking brake is set.
Also, I'm wondering if your linkage might need adjustment on your parking brake. When my brake is firmly set, the tractor won't move! :no: So, as a practical matter, I don't even need an indicator light to tell me I forgot to release the brake. :laughing:
   / Parking Brake dash warning light CK 35 / 4010 hst #18
The brake setup is different on the regular CK10 models than the CK10SE models. On the regular CK10 model the brake pedal pivot is below the floor board. On the SE models, the pivot is above in the steering column.
2011 John Deere 5085 70HP Utility Tractor (A55973)
2011 John Deere...
MULCHER (A58214)
MULCHER (A58214)
PALLET OF MISC (A58374)
PALLET OF MISC...
NEW Fork Extensions (A59000)
NEW Fork...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
2010 Freightliner M2 106 T/A Altec D2050A BR Digger Derrick Truck (A55973)
2010 Freightliner...
