Slope...what is safe?? Anyone here ever roll over?
   / Slope...what is safe?? Anyone here ever roll over? #91
The one universal thing you will see in almost all roll over tractor accidents is the FEL raised too high. At least the pictures of almost every one I have ever seen.
So for time being let's take the FEL out of the equation.
   / Slope...what is safe?? Anyone here ever roll over? #92
I thought a 45 degrees as it relates to hill sides is considered a 100% slope. So that picture of Moss Road's is a tractor on a 100% slope?
Yep. 100% slope. 100% grade. 45 degree angle.
   / Slope...what is safe?? Anyone here ever roll over? #95
I could ask your question another way;
Why do we always have this confusion about % slope and degrees of slope. Why in heck can't we all just use the EXACT same nomenclature when we talk about grades. Why not just use % slope. As in this is a 66% slope. Why do we need to refer to slope in degrees? Doesn't % define the slope exactly?
Both will define a slope exactly, but I contend that it is more visually obvious to specify slope by pitch. So, a 100%, 45-degree slope is a 1:1 pitch slope. Or, more commonly, my roof is a 3:12 pitch: 3 inch rise in 12 inches of run.
   / Slope...what is safe?? Anyone here ever roll over? #96
That works if you are a roofer, but at least it does make sense. I think degrees is easier. Grade is not something I would recall.
   / Slope...what is safe?? Anyone here ever roll over? #97
A square + B square=C square. Or put another way the sum of the squares of each side of the triangle = the square of the hypotenuse. Or so Pythagoras seemed to think. Learned that one in 8th grade math. Yeah I am old enough to have went to school when they actually taught some things.
The carpenters call it the 3-4-5 rule.
   / Slope...what is safe?? Anyone here ever roll over? #98
In the civil engineering world slopes are almost always described as percent slope or run over rise, such as 3 to 1.
   / Slope...what is safe?? Anyone here ever roll over? #99
Yet the highway grade is expressed in %.
   / Slope...what is safe?? Anyone here ever roll over? #100
And the very first thing that pops into my mind when I see one of those signs is: "how much is that in degrees". :)
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2022 Diamond T 14' Dump Trailer, VIN: 5FWDS1423NR030358, Manual Roll Top Tarp, Tandem Axle, 7 Gage (A59076)
2022 Diamond T 14'...
Giyi 72" Grapple (A57149)
Giyi 72" Grapple...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
UNUSED FUTURE CYHC MINI HYD 29" SIDE SHIFT FORKS (A58376)
UNUSED FUTURE CYHC...
New/Unused 7ft Work Bench (A57454)
New/Unused 7ft...
