3-Point Hitch John Deere brush hog on my GC 1710
   / John Deere brush hog on my GC 1710 #1
Action Jack
Massey Ferguson GC1710
I've reads some threads on here about using a JD 5' 127 brush hog or equivalent on a GC 1710,light duty use,just picked one up,my Massey has a FEL,BH so I have never used the 3 point,any idea what lenth arms or links to use for the brush hog,need to go buy some.Thanks
   / John Deere brush hog on my GC 1710 #2
I actually use a JD 5' Gyramor 205 on a GC1710 for more than just mowing grass... I've taken down 2 and 3" tree/saplings. If your referring to the 3pt arms/linkage it should have been included with the purchase of the tractor. Massey Ferguson/AGCO ships them with each TLB machine. Mine was folded up between the backhoe and the tractor upon delivery.
I bought it used,its 2 years old,no arms came with it
Can you measure yours for me.
   / John Deere brush hog on my GC 1710 #5
Here are pictures. I would strongly recommend speaking to the seller and seeing if they have the arms or speaking to a dealer. The setup is a lot more than just the arms with turnbuckles and particular bends to get around your backhoe plates and still function. That said it's about 14 1/2" from tractor pin center to the first sharp bend, about 6 3/4" bend to bend and about 3" final bend to center of the end ball. Top-link is a standard Cat1 limited top-link. The hard part will be the turnbuckle plate and the buckles in the right spot. All told it's pretty tight quarters once you run you PTO shaft in there. IMG_20190905_175153.jpgIMG_20190905_175200.jpgIMG_20190905_175205.jpgIMG_20190905_175210.jpgIMG_20190905_175426.jpgIMG_20190905_175430.jpgIMG_20190905_175436.jpg
Oh,wow,I thought they were just like a large tractor,just a couple adjustible bars,thats a whole different deal,thanks for the picks,I'm a welder fabicator,my buddy has same tractor,maybe I"ll borrow his and copy,thanks a bunch
   / John Deere brush hog on my GC 1710 #7
You're welcome, good luck!
CASE CX57C EXCAVATOR (A52707)
CASE CX57C...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2023 John Deere 6155M MFWD Tractor (A53485)
2023 John Deere...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2014 Ford Fusion (A56859)
2014 Ford Fusion...
2009 John Deere 7130 Premium (A53317)
2009 John Deere...
