Kubota 5460 skid plate
   / Kubota 5460 skid plate #1
buck12
Mississippi
Kubota 5460HSTC
BF6BB2C2-7096-4BA1-A325-01FE293D0271.jpeg3A7F4708-FF98-49B6-B1E3-63184C6B4E5E.jpeg34EF45A1-4B09-499F-92E0-E14BF6AC5C54.jpeg67380CF2-4338-4354-956D-5EC485A8D61C.jpegE2B9457F-0CFE-41D2-8B31-883158D57C8B.jpegB0B4CDA8-982C-4764-9BA1-67E164BA548E.jpeg
I finally got the skid plate made and mounted to protect the fragile under side of my Grand L. I originally only planned to protect the third function hoses but then decided to extend the plate back a little further to provide some protection for the filters and metal lines as well. Sorry that the phots are not the best. I tried to get a picture under the tractor but there was not enough room to get a decent photo.
   / Kubota 5460 skid plate #2
Very nice. The underside of my M6800 is also fragile. Where did you get the plates? Were they custom made? I didn’t know Kubota made any.
I had a coworker make it. I made a cardboard template that he used as a pattern.
   / Kubota 5460 skid plate #4
That came out nice. Smart to cover those filters. They are a big thin skinned target.
gg
   / Kubota 5460 skid plate #5
Like to see well thought out, fabricated and installed solutions for obvious poor factory engineering. Need to make some skid plates for my tractors too.
gg
The hydraulic filters are tucked away on this tractor but a stick could still find its way. Several years ago I had teed log crush the hydraulic filter and break the cast fitter housing on my Mahindra. I think there is probably an old thread on TBN about that incident.
   / Kubota 5460 skid plate #7
You're lucky they are tucked away. On both my Kubotas they are hanging right out there. Once bit, twice shy is a good way to go though.
gg
   / Kubota 5460 skid plate #9
Nice work Buck!!!
Gordon, mine are vulnerable too. I went forward and protected the valves as well.
   / Kubota 5460 skid plate #10
Nice job on the 3rd function protection. I'm not much on metal work, so I ordered the kit that Paul Shorts sells (Specialty Repairs).
After hitting my rear high flasher lenses several times I also got his light guards.
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
2017 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2025 JOHN DEERE X350 LOT NUMBER 166 (A53084)
2025 JOHN DEERE...
1977 GMC GENERAL TANDEM AXLE DUMP TRUCK (A52577)
1977 GMC GENERAL...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53342)
THIS WILL BE A...
