How do you verify if the tow/haul button actually works?
   / How do you verify if the tow/haul button actually works? #11
Go 58 mph push switch and watch rpms go from 1800 to 2100, basically it takes the tranny out of high or OD. It痴 noticeable with or without trailer.
Jim.
   / How do you verify if the tow/haul button actually works? #12
I would say need to find a buddy with a GM Tech2. It will tell you what is going on.
Jim.
It turns 2,000 at 60. Pushing the tow haul button does nothing.
   / How do you verify if the tow/haul button actually works? #14
There is no mistaking the Tow position on my 08 Duramax. Louder, higher Revs, shifts totally different.
   / How do you verify if the tow/haul button actually works? #15
Pretty noticable on my beater 2005 F250 as well. Shift points jump way up & it gets a fair bit louder as a result, even if you arent keeping an eye on the tach. Engine beaking is there too, but less consistent & not as noticable.
   / How do you verify if the tow/haul button actually works? #16
On my 2015 F250 push on the Tow/Haul button before a descent. Hit the brake about medium pressure as you pick up speed it will almost always downshift.
   / How do you verify if the tow/haul button actually works? #17
i have 01 1500 silverado w/4l60e trans. tow/haul changes the shift patterns... but will still go in OD. hauling and towing i take it out of "D" (overdrive) and drop down to "3" (no overdrive), mainly in the mountains.
   / How do you verify if the tow/haul button actually works? #18
Go 58 mph push switch and watch rpms go from 1800 to 2100, basically it takes the tranny out of high or OD. Itç—´ noticeable with or without trailer.
Jim.
Actually you could go any speed after the transmission shifts to high then press the trailer tow button. It the RPM doesn't change then your tow button isn't working. Alternately to check if the transmission is not shifting to OD just get up to 60 MPH with the tow button engaged then turn it off and note if the RPM gets a couple hundred revs lower, it not then your transmission is not shifting for some reason. This might require a tech to determine the cause,-I know it would in my case.
   / How do you verify if the tow/haul button actually works? #19
My chevy does that, hit brakes going down hill, it will downshift with tow mode.
   / How do you verify if the tow/haul button actually works? #20
It also locks the torque converter more, to prevent it churning and producing heat.
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
1994 Club Car Electric Cart (A56859)
1994 Club Car...
2025 Forklift Safety Basket (A56857)
2025 Forklift...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
SKID STEER ATTACHMENT SHREDDER (A58216)
SKID STEER...
