Curtis Cab Roof Work Lights
   / Curtis Cab Roof Work Lights #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
Hello,
Would someone recommend replacement Curtis Cab Roof Lights for my JD 4310. Just not sure if I should go with Halogen or LED work lights . . . primarily for snow blowing at night.
Thanks,
FredSG
   / Curtis Cab Roof Work Lights #2
LED all the way.. They use little power, last a long time and are very bright.. A 4inch flood on all four corners is what I use, lights up the work area like daylight..
Atsah,
Which LED Work Lights are you using? Where is Maine, as you listed?
FredSG
   / Curtis Cab Roof Work Lights #6
Atsah,
I want to hook the lights you recommended to a 6 Rocker Switch Panel - one Rocker is the main and each of the other Rocker switches control other electrical devices on my 4310 . . . I have a 20 amp fuse on the power line going to the Rocker Panel. Will the LED lamps work with this set up . . . any idea?
FredSG
   / Curtis Cab Roof Work Lights #8
I don't see why not, they draw very little.. I hooked all four to my headlight switch so when I turned on my headlights they all came on..
Atsah,
Thanks so much for taking the time to reply . . . very much appreciated.
Off to Amazon!
Fred
   / Curtis Cab Roof Work Lights #10
Atsah,
Off to Amazon!
Fred
Pm me if you have any further questions when you get them, good luck...
Mark
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
