Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #9,491
I have a Marlin 30-30, great deer gun, but after the hunt and before I get in the Jeep, it's jack and rack cause I think it's against the law to have a loaded gun in a vehicle, I think.
I believe it depends on the state in which you reside. I never drive to hunt, just walk out the back door... and I'm hunting!
   / Tractors and wood! Show your pics #9,492
I'd like to have something like that, that will straighten out a 8'-20' board, everytime I let broads dry they get crooked. Maybe a kiln would solve the crooked board problem, stack them then clamp the broad down with 100 ton clamps or a giant press.
I've gone to stacking mine and then ratchet strapping the bundle to control some of that twisting . Harbor freight has packs of ratchet straps on sale for $6.99 all the time. When I first started milling my own wood about a year and a half ago I remember seeing pics of people with cinder blocks and anything else heavy on their piles.. I thought there better be a better way.
   / Tractors and wood! Show your pics #9,493
I was in the driveshed tonight. The whole shed smells of that stuff. Kind of like apple, but not quite. I had thoughts that it would have made furniture wood, but am telling myself that it wasn't straight enough.
Any chance you have sweetgum up there?
   / Tractors and wood! Show your pics #9,494
I think liberty Maine is a good bit farther than 29 miles but I壇 want $200 to deliver 3 rick 30 miles. That痴 a tight hand tossed load that痴 bigger than I usually haul. I壇 say it痴 closer to 4 rick.
Who's Rick?
   / Tractors and wood! Show your pics #9,495
Hauling some logs from my woods over to my sawmill..
After first load (pyramid stacked) I found out they were hard to get off the trailer with the grapple, so I put landscape timbers between levels and fixed the problem.
Pics were taken with my phone in the upright position, look fine on my phone and the computer, they get sideways loading them here for some reason!! Grrrr
   / Tractors and wood! Show your pics #9,496
I was going to try that but if I damage the line then I have a bigger problem that will require fuel line hunting and or a trip to the tractor store and more speaking in tongues. I usually have better luck un-clamping a line then sticking a bolt in the end, if the end gets damage then I can cut a inch off for a new section, theoretically of coarse............
Some places (maybe harbor freight or NAPA) carry a special pair of pliers especially for crimping hoses, they kind of look like a cross between vice grips & small needle nose pliers, they have flat pads instead of teeth that just gently pinch the hose shut, but no sharp edges to puncture the hose. I bought a pair & thought i'd only use them once, but I use them a lot more often than I thought.
   / Tractors and wood! Show your pics #9,497
I have been here a while and this is the heaviest wood I have ever processed. Dark color, smells kind of weird and gets into your sinuses. The heviest rounds at the trunk I could not even think about lifting and had to move them with a grapple.
I remember cutting a couple apple trees that smelled kind of like funky cheese.
   / Tractors and wood! Show your pics #9,499
Not sure, but do the 3 or 4 Ricks help restack the wood after you dump it out of the truck? :laughing:
I know I don’t. I’d rather split it as stack it.
   / Tractors and wood! Show your pics #9,500
I know I don稚. I壇 rather split it as stack it.
Hummm...
I have to cut it..
Stack it....
Split it.....
Load it.....
Haul it....
Unload it....
Stack it.......
Load it again.....
Haul it....
Unload it....
Stack it.......
THEN I get to burn it.
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
CONTAINMENT SKID MOUNTED (A55745)
CONTAINMENT SKID...
2014 Chevrolet Traverse 2LT SUV (A55853)
2014 Chevrolet...
1998 National RV Tropi-Cal T/A 35FT Class A Motorhome (A55853)
1998 National RV...
