GC1705 MMM deck!
   / GC1705 MMM deck! #21
GeneV I have had the same bending problem. I was surprised how easy it bent back. I was thinking that mine bent when I drove over the deck. Now I am super careful with that area.
   / GC1705 MMM deck!
Another trick that I have found works really well for the mid-mount PTO drive shaft - if you need to separate the two halves (maintenance/clean/lube), mark their orientation with a silver Sharpie or paint pen - the halves go back together much more easily.
That is what I was thinking of doing yesterday when I was out doing some loader work. Thanks.
Jim.
   / GC1705 MMM deck! #23
Ditto on marking the shaft -- I did the same thing, since it will only fit one way. That was a bit of a surprise, but I suppose it's to keep the u-joints correctly aligned.
   / GC1705 MMM deck! #24
I wouldn't rule that out, there's not much clearance there between inside edge of tire and that pin if it's pulled back and locked in detent.
   / GC1705 MMM deck!
I noticed how close the pin was right away to the front tire and put mine back in, I can see how a person could run over it when driving back on the deck, something to keep a eye on for sure.
Jim.
   / GC1705 MMM deck! #26
Yeh, I also turn them in before driving over the deck. The manual outta be more specific about that.
   / GC1705 MMM deck! #27
So as I read your post. You rotate the pto on the mmm by using the belt? I just turn the shaft on the tractor with my hand. I put the pto on the tractor in neutral and turn it. So basically once I get the MMM hooked up. I grab the PTO and immediately try to marry it to the tractor. First attempt fails, I simply rotate the tractor PTO and try again. Once it slides on as far as possible. Seems to be about an inch before you have to pull back the mechanism for connecting. I use to pull that back right away but you don't need to. Just align it, slide it on, pull back mechanism, then slide the rest of the way.
You guys are making it harder than it really is. Trust me
Disconnecting the deck is no biggie. As for connecting, I never mess with the wheels (mine are set somewhere mid-height), I just leave them as is and drive the tractor over the deck with no problems. But connecting the shaft is the major league pia for me, it just flat out sux. The best method I found to mate the shaft with the pto is to rotate the shaft using the deck belt, that way it rotates the shaft very easy as opposed to having to rotate it by hand. When I feel it catches the splines of the pto, then comes the struggle pulling back on the snap ring to slide the shaft on. I haven't found a good technique to make this process easier, hopefully it will come to me.
One thing I found on the deck, the housing holding the slide pins can get bent a little from holding up the deck, off-setting the pin a little bit so that it doesn't line up perfectly with the hole in the tab it's supposed to go in. If you notice it's hard to pull those pins out when you're taking the deck off, it will be even harder to put them in fully when you're mounting the deck, and the following time they won't even fully engage with the tab...meaning your deck is not properly attached to the tractor. If you see that happening, the simple remedy is to hook a pry bar or something along those lines under the pin, using the fin (just underneath my thumb in that pic) as leverage. Just pry up on that pin, which will bend the housing it slides in enough to line it back up with the tab. The pic shows how the pin wasn't going fully in the tab until I bent the housing back into place.
   / GC1705 MMM deck! #28
Ed, I'm sure you're right. I haven't got the technique down pat yet, still fairly green with this tractor. Are you using one hand for all that?
   / GC1705 MMM deck! #29
I'm with Ed here. I leave the tractor 2000 PTO out of gear so it spins freely by hand and roll it with a finger until the deck shaft marries up to it.
   / GC1705 MMM deck! #30
edgarrian is correct. Marry the splines on the shaft to the mid-PTO first, then and only then pull back the collar, slide full-on, release collar, pull back to lock.
24008 (A53422)
24008 (A53422)
2018 Chevy Equinox (A56859)
2018 Chevy Equinox...
WHIRLPOOL STAND UP FREEZER (A57192)
WHIRLPOOL STAND UP...
UNUSED JCT 72" HYD TILLER (A57193)
UNUSED JCT 72" HYD...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
