Price Check 135 oil leak
   / 135 oil leak #1
JTXN
Member
MF 135
I recently purchased this tractor from my father in law. He said there has been an oil leak for a long time and he just checks both the engine oil and hyd oil before each run because it would require alot of work to fix. Tractor runs fine, the only thing i noticed is after running for a long time, with the clutch all the way down, the engine PTO will not stop spinning. Maybe because there is oil in the clutch from a bad rear main seal?
Second, I noticed a bolt is missing on the plate below. I'm assuming it fell out or is stripped. I'm thinking about removing one of the other bolts and seeing if it will fit. I can stick my finger up in there and feel threads and alot of gunk. If it does fit without stripping then purchase another bolt.
Should I pull the whole plate, replace the gasket and reinstall?
The oil leak below is after about 3 hours heavy mowing at 95 degrees. It is clearish and does not look like black engine oil. Looks like alot but it did not leak through the cardboard and does not leak when its sitting. Hyd oil dipstick shows "low". I don't really want to split the tractor, so is adding a little hyd fluid the 4 or 5 times a year I work it acceptable? 20190916_200532.jpg20190916_200539.jpg
   / 135 oil leak #2
That plate is just a access to the clutch and to adjust the PTO clutch.
   / 135 oil leak #3
What oil does you use on the rear? Hopefully not hydraulic oil?
   / 135 oil leak
I haven't put any in yet. I was going to get some from tractor supply.
   / 135 oil leak #5
   / 135 oil leak #7
same here
   / 135 oil leak #8
Hydraulic oil and 10/30 Universal tractor oil are very different, the first are thin as water and I have seen several times that pepole use hydraulic oil because the tractor has hydraulic, that's why I asked.
   / 135 oil leak
I get it, like fluid for a log splitter
   / 135 oil leak #10
It says hydraulic fluid in the owners manual it needs to meet spec m-1129a and tsc premium does
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
Rolling Cart, Wire Basket, and Stand (A50325)
Rolling Cart, Wire...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2019 KENWORTH T880 (A52472)
2019 KENWORTH T880...
