Selecting tractor size for vegetable farming with greenhouses
   / Selecting tractor size for vegetable farming with greenhouses #11
Can you explain the concept of liquid filled tires to me? This is a foreign concept to me. Is it just for added weight on the back of the tractor? Would this be needed no matter what type of tire I go with? I was leaning towards Ag tires on the front and back.
The early compact tractors were English Fergusons and Ferguson derived US Fords; both were solely 2-WD. Loading/ballasting rear tires with liquid, ballasting wheels with iron wheel weights, or sometimes liquid ballast AND wheel weights, increases tractor rear tire traction. Remains essential for 2-WD tractors today.
Now that most tractors are 4-WD loaded rear tires are less important unless pulling ground contact implements is a main focus, as in your case. You will need all the traction you can get for your application with a 2,700 - 2,.900 pound bare weight tractor.
Heavier tractors have more weight on the tires but also pull heavier implements.
Too much rear wheel/tire weight on 5,000 pound plus tractors can lead to soil compaction. Not an issue at 2,700 pounds.
All of my three tractors have had tires inflated with air. Soils in Florida are soft sandy-loam and a tractor can sink in easily. Air works for me.
MORE (2): Comparing Types of Liquid Tire Ballast | OrangeTractorTalks
6 Reasons to Liquid Ballast your Kubotaç—´ Tires | OrangeTractorTalks
How To Choose the Right Tires for Your Tractor
   / Selecting tractor size for vegetable farming with greenhouses #12
[video]https://www.google.ca/search?q=root+vegetable+undercutter&client=safari&hl=en-ca&prmd=isnv&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjM4ti9y9rkAhXplOAKHR6zAbkQ_AUoAXoECA4QA Q&biw=1024&bih=671#imgrc=qaLkm_LpgV4_jM[/video]
If this is the type of root cutter referred to properly set up on the three point hitch it could add considerable downforce on the rear tires that would significantly increase traction.
It could also be sized to use as a cultivation tool between vegetable rows. ( might require row spacing that is inefficient? ) It would also work for secondary cultivation acting much like a rod weeder.
Sorry, newbie question: If I'm doing tillage in a greenhouse without the FEL, do I need to have some type of ballast box on the front to counter balance?
   / Selecting tractor size for vegetable farming with greenhouses #14
Rule of thumb for tiller, bush hog is 30hp for 5' width.
   / Selecting tractor size for vegetable farming with greenhouses #15
~ No. ~
   / Selecting tractor size for vegetable farming with greenhouses #16
I would suggest going a bit bigger than what you need right now.
If you're buying new, some FEL come off and on quite easily so that can help with maneuverability in the GH.
Where in Ontario?
   / Selecting tractor size for vegetable farming with greenhouses #17
Generally, you ballast the rear wheels so that they stay on the ground when doing loader work...
Rule of thumb is about 5hp/foot for most such tools.
~ No. ~
It depends on what you are running. A tiller or something else that sits close, probably not.
A transplanter or something else that puts a lot of weight out behind the rear wheels? Definitely.
Aaron Z
2022 Horizon (A55973)
2016 Volkswagen Jetta (A56859)
2016 Volkswagen...
30in Hydraulic Forks Skid Steer Attachment (A56857)
30in Hydraulic...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
