B2782B Snow Blower Shear Pins
   / B2782B Snow Blower Shear Pins #11
They had different part numbers,but were not the usual 10 digit Kubota numbers.almost like an in house number.
How did you ever make out with your exhaust issues?
Thanks for the info.
I went ahead and ordered a dozen of each of the shear bolts based on parts numbers on the parts breakdown.
Now all I need is some snow. I hope we get more than last season. We didn't get anything near what I needed to use the blower.
I have not been able to pursue the dang diesel odor in the cab.
I just cut the grass a couple of days ago and the diesel smell was pretty strong/oppresive. Once again, it permeated my clothing.
I have tried closing the air vent, opening the air vent, looking for fuel leaks, but that's it so far.
I have not tried pulling the top off yet due to the amount of work that requires.
On a good note... I DID get my LD work lights installed ! :.)
But ya... I gotta fix the odor problem.
   / B2782B Snow Blower Shear Pins #13
Is the diesel smell an exhaust smell or fresh fuel smell? I have no cab but my exhaust tail pipe took a ding, cracked it at the lower mount, and I only noticed it after getting alot of exhaust stink wafting towards the cab, which wasn't there before. When I had the tail pipe crack welded I took the whole pipe off at the muffler to do the weld better, and saw (barely) that the tail pipe had loosened (crack barely visible) where it joins the muffler. Fixed that too. But the muffler joint crack was not visible when muffler mounted to engine manifold.
Look carefully, a small exhaust crack can send fumes back to the cab making a very noticeable difference.
   / B2782B Snow Blower Shear Pins #14
I've broken 10-15 auger shear bolts for the one impeller shear bolt I snapped - that one was a rogue wood block that made it past the augers and jammed the impeller. Most of the auger shears are from our driveway (and one of my neighbor's) and parking area as we have pit run gravel regularly offering up 2-3" + stones to jam it. All bolts are Kubota supplied parts.
This year I'm taking the box scraper to the gravel and burying and smoothing over and compacting the gravel before freezup, and lowering the blower skid shoes at the beginning of snow season until the ice layer at surface solidifies, then can run it at fully lowered position.
It's a fume odor, not so much raw diesel.
Thanks for the info on the hidden exhaust crack. I'll do an inspections all along the exhaust system that I can see, or get to.
When I send the tractor for annual service, I'll have the dealer look for possible causes.
I just read another post about a person with a 2650, who had posted pictures of a break/crack of the pipe right at the muffler.
It was pretty large, but then again, unless you are looking for it, it can go unnoticed other than the odor.
   / B2782B Snow Blower Shear Pins #16
Was that other post mine? I did post about it with pics earlier this year.
YEP ! Sorry..... I just had a "duh" moment........
   / B2782B Snow Blower Shear Pins #18
Tim,a quick check for an exhaust leak would be to cover up the exhaust pipe outlet briefly with a shop towel(rag)with the ehgine running.
You'll hear a leak right away,or if no leak,it'll build pressure against your shop towel.
Good Luck!
number two,
That sounds like a quick and easy way to check for leaks.
I will definitely do this as soon as I get a chance.
I will remove the engine side covers at the same time to help me hear any leaks.
Thanks for the suggestion.
Regards.
   / B2782B Snow Blower Shear Pins #20
Also when checking for leaks I could feel little exhaust "gusts" from the cracks simply by putting my hand (carefully) close to the area with potential leaks. These are pretty loud engines, sometimes easier to feel the leak than hear them.
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A56857)
2024 AGT LRT23...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
6' LANDSCAPE RAKE, 3PT (A52708)
6' LANDSCAPE RAKE...
2018 Cadillac Armbruster 70 IN Limo - Only 49K Miles - Luxury Transport, Clean, Well-Maintained (A56435)
2018 Cadillac...
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
