Anyone know the Hydraulic system pressure rating for an Iseki TL 2101 FD?
   / Anyone know the Hydraulic system pressure rating for an Iseki TL 2101 FD? #1
JRP3
Member
Iseki TL-2101FD
Trying to find what pressure the hydraulic system is supposed to run at for this tractor. I have a log splitter plumbed into the power beyond port from the Koyker 155 loader on the tractor and it's not performing as I expected.
I put a gauge on it and get a max of 2000 psi. Don't know if that's what it's supposed to run at or not.
   / Anyone know the Hydraulic system pressure rating for an Iseki TL 2101 FD? #3
Mines a different model, however mine too is very weak (2000psi), just need time to pull the pump off to see what sort of drive it has (apparently there's two types) in order to replace it.
As far as I know, there's no pressure relief valve in the pump.
   / Anyone know the Hydraulic system pressure rating for an Iseki TL 2101 FD? #4
@Marcle: i sent you a pm or email with a question about your double wheels, but never got an answer.
Any chance you can send me pm with a description on how you did this?
Last weekend i almost sided for the second time, i would really like to solve my problem. Hope you can help me.
Looking at the data for a similar vintage and sized Kubota L245 it also shows 2000 PSI system pressure, at 3.7 GPM. TractorData.com Kubota L245 tractor information Here's an Iseki TX2160 showing 1850 PSI at 2.7 GPM TractorData.com Iseki TX216 tractor information
Has to be a pressure relief valve somewhere in the system.
   / Anyone know the Hydraulic system pressure rating for an Iseki TL 2101 FD? #7
My pressure was before the PRV as I rerouted my pipework to take advantage of maximum pressure, but did not gain any additional pressure.
Is there any sort of PRV in the pump?
Don't know, I just found those pics, they aren't mine.
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
1998 Chevrolet 1500 (A53314)
1998 Chevrolet...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
