YMandM
Hey guys, very interesting reads on some of the projects and things I致e e read/seen. I have a small landscaping company that I use as a side job to help cover the costs of my kids sports and have been using a friends 1991 Case 1130 for some of the larger projects Ive been working on. I found a 2013 Branson 2400 at what used to be big reds and purchased it to start taking on more projects in my area that are on properties that are 1-5 acres, small shredding, pulling small amounts of timber and some box blade work... I was sceptical at first to go to a compact because the footprint seemed so much smaller then the case but seems like the power number are about the same so hoping its エ up to the task. I know weight is key, 2400 is about 200 lbs lighter. Couple questions;
- I want to convert the bucket to a quick attach so I can make a boom and a few implements for it, I found a bolt up kit on eBay that says it fits the SL100 I have the SL00, will it fit? I can遞 post links being new on the forum so here is the item number 332792692776
- Brush hog - can I use a 5 foot and not be under powered? Are the countryline units that are squared off on the back ok, is there any advantage to the units that are for tighter clearance that are round in the back?
- Box Blade, ok to use 5 foot, power requirements enough?
