Bazman72
I have a Yanmar 165D with an aftermarket loader (from Coldwater Tractors in WA). It started making a high pitched noise which appears to be in the under the seat/transmission area. I am interpreting this as a likely hydraulic leak noise.
When I had the loader installed they said the hydraulics for it ran off the transmission. I checked the trans fluid level and it's low, at the bottom of the dipstick. It hasn't been checked for a while. I didn't see any fluid leak or puddle under the tractor.
The manual says to use John Deere 303 Hy Gard for the transmission. I don' t know what fluid is in there since I have not changed it since I bought the tractor (3rd hand). Could I add the JD303 and run it while I look for the leak? Could that fluid react badly with whatever is in there (probably JD303 since the previous owner seemed meticulous)?
Any recommendations for a tractor rookie with a problem?
Thanks!
Thanks!
