Need JRW Snowblower Impeller blade
   / Need JRW Snowblower Impeller blade #1
Blowingsnow
John Deere 5320
Hello,
I need to replace impeller blade for 2004, Model S70 JRW blower, 26" fan, four blades. Welder says he can fix but might take 6 or more hours, It's pretty beat up from years of blowing rocky roads! I understand JRW is no longer in business? Might just have the welder go to it, but thought I'd ask around. Thank you!
   / Need JRW Snowblower Impeller blade #2
You might take some measurements then measure other blower brands to see if one of them will interchange with yours.
   / Need JRW Snowblower Impeller blade #3
What is the depth of the drum and the gearbox shaft size? 26 inches is a very common snowblower fan size but the depths do vary.
A few years ago we had to check about getting a 26 X 10 fan made and the quote was $6-700 Canadian.
I'll do that, thanks!
I'll have to measure and see, thank you!
LOT: (48) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #1 Grease (A59076)
LOT: (48) 14 Oz...
INOP Mitsubishi MXR55 Mini Excavator (A57453)
INOP Mitsubishi...
EZ-GO Electric Golf Cart (A57149)
EZ-GO Electric...
1707 (A58375)
1707 (A58375)
(4) Motreal ST2051/7515 Tires (A57149)
(4) Motreal...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2012 NORAM POWER...
