AZUNO lock-on grase fitting coupler?
   / AZUNO lock-on grase fitting coupler? #2
I don't have that particular brand, but it appears well made in the picture (for whatever that's worth!)
I do like the concept, and have been using the LockNLube brand for the past year. Coupled with a DeWalt electric grease gun, I almost enjoy greasing! My Kubota ZD mowers have like 15 grease fittings, so anything that makes the job easier is a big plus.
Thank you
   / AZUNO lock-on grase fitting coupler? #4
Looks well made but reviews are mixed on it.
I also have a LockNLube on a Dewalt gun. I have mixed results with it but I'm too lazy to change it. Sometimes I have trouble getting it to lock on. Some fittings I have to use a short extension with the standard coupler on because the LockNLube won't get to it. One of these days I'm going to just stick the regular coupler back on the gun.
   / AZUNO lock-on grase fitting coupler? #5
I have a Lock-N-Lube unit. I've quit using it with my DeWalt electric grease gun. The outside diameter of the L-N-L unit would not fit into some of my recessed grease zerk locations. This unit might be better. It just might be a tad smaller in diameter. At least, enough to fit into my recessed locations.
   / AZUNO lock-on grase fitting coupler? #6
I have the "Lock & Lube" unit and it will not fit in any of the recessed fittings on my 3054 Kioti
   / AZUNO lock-on grase fitting coupler? #7
Never seen the need for a 'lock on coupler'. Ordinary grease couplers (at least most of them) are 2 piece. The nose and the body are seperate and the nose applies pressure on the collet assembly that grips the end of the Alemite fitting so, if you want a firmer grip, just tighten the nose, looser grip, loosen it.
In my view, the lock on couplers are a solution looking for a non existent problem.
   / AZUNO lock-on grase fitting coupler? #8
These lock on couplers seemed to be the talk of web a while ago.???
   / AZUNO lock-on grase fitting coupler? #9
Clearly the LockNlube style is not for everyone. It fits in the recessed zircs on my L4060 FEL, and makes my greasing routine easier, and faster.
   / AZUNO lock-on grase fitting coupler? #10
I have one of each. A Lock n'Lube and a Azuno. The Azuno is MUCH larger that the LnL. There's no getting into tight spaces with the Azuno.
DEWFPO
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
