Are these forks a good fit for my Kubota BX?
   / Are these forks a good fit for my Kubota BX? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
Ok, I don’t even have a BX or own these forks but it seems like a good combination... IMG_7615.JPG
   / Are these forks a good fit for my Kubota BX? #2
Those look perfect for a BX, should be able to pick one up, no problem. Of course, if you put them on the front of a BX, it will still pick it up, or at least the rear end.
   / Are these forks a good fit for my Kubota BX? #3
Those look waaay too large for your BX. They have the lowest FEL lifting capacity in the subcompact class of machines. Ideally you wanna find a ultra light pin on set of forks made specifically for the BX tractors to have them actually be functional.
   / Are these forks a good fit for my Kubota BX? #4
Are you really SURE they are "waaay too large"?
   / Are these forks a good fit for my Kubota BX? #5
Since you have neither a BX nor the forks I'm sure they're perfect for whatever purpose you have in mind.
   / Are these forks a good fit for my Kubota BX? #6
Those forks and the top pin hole are part of a pin over bucket system or slide into a large frame meant to hold them. That type of fork is usually found on larger forklift units vs the sliding C rail system of many lighter duty options.
You must’ve missed the sarcasm here. Those forks are probably off a 15 ton or bigger loader.
   / Are these forks a good fit for my Kubota BX? #8
It would be nice to see a BX parked next to those monsters. :shocked:
2024 ArmorLite Aluminum End Dump Trailer (A56438)
2024 ArmorLite...
14C SCRAPER (A58214)
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56438)
2017 John Deere...
