Canopy Adding Rear Remotes GC1710
   / Adding Rear Remotes GC1710 #1
cglaser104
Lockport, NY
Massey Ferguson GC1710, Cub Cadet 2206
So I've been considering this for awhile. I wanna have the ability to run rear remotes for various tools as well as run a hydraulic top link. Has anyone tried to do this just yet?
My plan is to used the backhoe plumbing to plug into a 2 spool valve body when I don't have the backhoe mounted to accomplish this using QC's. I'm going to try a summit hydraulics 2 spool, 1 with detent float valve. It's probably too tight but I'll also look to run the levers through the vacant slot next to the other hydraulic lever. At the least I'll have to fabricate different handles to connect to the body.
I'm also torn on top link options as the factory manual top link has a span range of 14"-20" or so. The problem I'm having is hydraulic toplinks I can find are either 14 3/16"- 18 1/2" OR 16 1/8"-22 7/16". Anyone seen anything more like a 14/15-20/21 or so?
   / Adding Rear Remotes GC1710 #2
I can build you a 15"-20" working length unit. :thumbsup:
   / Adding Rear Remotes GC1710 #4
14"-18" or 15"-20". It is basically impossible to build a hydraulic unit and have the range that a manual link has. You have all the internals to deal with that a manual link does not have. ;)
I can play with those dimensions about 1/2" + or -. But making things shorter can cause other issues that I prefer to stay away from. ;)
So 15" as a solid minimum but doing what you can to stretch the other end as close to 21" as possible might be a thing?
   / Adding Rear Remotes GC1710 #6
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2018 Allmand...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
