   / Harbor Freight Tools that don't suck #12,021
E10 has been around for what, 20 years now? One would think that small engine makers would have figured out how to work with it by now.
As you said, use fresh gas and run it dry if you're not going to be using it for a while and you'll be fine.
What's all this got to do with HF?
Not much unless it involves Predator engines....:laughing:
I turn the fuel off on my seasonal Preds and run the carbs dry on them as well and I fill the fuel tanks completely full of gas with Marine Stabil in it.
HF has a winner with those engines, I have 3 and one replaced a Honda that tossed a rod. One on a tiller, one on a pressure washer and one on a push mower. Tiller had the Honda that puked, pressure washer had a Briggs that used more oil than gas and the push mower came with a blown Tecumseh.
   / Harbor Freight Tools that don't suck #12,022
A gas chain saw hazard we didn't expect:
Cal/OSHA officials are investigating a firefighter injury while they were using a chainsaw to conduct Kincade Fire firefighting operations when the fuel cap came off and splashed their pants with fuel, which set on fire and resulted in second and third degree burns. The worker was taken to the UC Davis Medical Center Burn Unit.
That specialty clinic 100 miles away is for the most severe burns.
That's not the first time that's happened to a wildland FF. There are other stories out there.
   / Harbor Freight Tools that don't suck #12,023
I do the same thing as 5030 does in post #2012. It only takes a couple of minutes to drain fuel out and then run machine until it dies; then whenever I need it again it always fires right up with no hiccups at all.
So do you drain that fuel back into the can or what? And why is it any better stored in the can as opposed to stored in the saw?
   / Harbor Freight Tools that don't suck #12,024
Watched a you tube vid about just that and the guy in the video said Motion Pro was coming out with a insert fix, Went on their website and saw nothing. he did say the fix cost a bout a hundred bucks a cap. For that price I'll keep the quarter turns.
Yep, I just got a new set for my MS260...
   / Harbor Freight Tools that don't suck #12,025
I just received an email flier w/ a "10% off entire purchase" coupon but when u read the fine print, as to what u CANT use it on, it lists practically the whole store..
   / Harbor Freight Tools that don't suck #12,026
I have one of their 212cc engines in my log splitter that replaced a 30 year old B&S and I agree...it's a good engine for a great price. Quieter, more fuel efficient and easier to start than the B&S ever was.
Local small engine guy who recommended it told me their horizontal shaft engines are good, the vertical shaft ones not so much. True?
   / Harbor Freight Tools that don't suck #12,027
The one on the free bee rotary mower my wife uses in the front yard has the vertical shaft motor and it has been just as reliable for us. Not sure about the larger V twin vertical engines. My Kowalski on the zero turn keeps humming along, has been for 10 years now.
   / Harbor Freight Tools that don't suck #12,028
HF is getting very selective about what you can and cannot use a coupon on and the 'fine print' requires a magnifier to read...lol
I belong to the 'inside track' club so anything marked in orange is much cheaper.
Bought a Gardner knife sharpener the other day, 3 bucks to replace the Chief's Choice we have in the kitchen drawer that has about expired. Didn't expect much but was pleasantly surprised, it does the job and uses ceramic rods placed at the correct angles. Should last a good long while.
3 bucks don't break the bank.
   / Harbor Freight Tools that don't suck #12,029
hunt4570, Yes I drain it back into the can but that's mostly because I'll be using another 2 cycle engine soon (trimmer, blower, weed whip, etc.etc.) and I'd rather use it up so that when I do use the saw again it will now be a fresh batch of mix. Plus, I don't have a fuel shut-off on the saw or other small engine machines so I need to drain the tank to run the carb dry. Greg
   / Harbor Freight Tools that don't suck #12,030
What about using Stabil in the gas?
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
Mini Excavator (A55787)
Mini Excavator...
Portable Restroom (A54865)
Portable Restroom...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
19010 (A55851)
19010 (A55851)
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
