TO20 starting
   / TO20 starting #1
bpcrshooter
massey ferguson to20
so someone at some point removed the orig starter solenoid and the rod that comes from the shifter, is there a way to get a new rod?? I found the solenoid but have had no luck finding that rod. thanks Matt
   / TO20 starting #2
If you can't fabricate one perhaps you can find one on a website dealing especially with old tractors. By the way, I think it's a Ferguson. I think Harry was selling them after he broke off from Ford but before he went in with Massey.
   / TO20 starting #3
what is the purpose of a rod going from the shifter to the starter solenoid?. that's baffling, as there don't seem to be a useful purpose in doing that.. why not just use a modern solenoid?..
   / TO20 starting
you use the shifter to start the motor. when you push it forward it uses a rod to move a cam that pushes on the starter solenoid.
   / TO20 starting #5
ah a very early neutral safety switch.. I've been reading it's easy to drop the rod into the clutch bell housing, yours could be sitting there..
   / TO20 starting #6
It's a safety issue. You use the transmission shifter to actuate the starter switch so you can't start it in gear.
   / TO20 starting #7
Agree with an earlier post. I bet the rod just fell down when the previous owner was replacing the start solenoid. I almost dropped the rod myself! Get something long and magnetic and fish a round inside with the starter solenoid removed.
   / TO20 starting #8
Agree with the magnetic pickup or even a coat hanger bent for a hook. The rod attaches high and to the right of centerline. Easy access if you take the steering off, but thats a lot of work. May have to if you fabricate a rod. If I remember correctly its just a small rod with a 90 deg bend on each end and hole for cotter pin. The adjustment is sliding the switch mount forward/aft, slotted mounting holes.
2017 CATERPILLAR 299D2 SKID STEER (A51246)
2017 CATERPILLAR...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2017 Dodge Journey SUV (A51694)
2017 Dodge Journey...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
