Hydraulic cylinder rebuilding. How to purge the air out?
   / Hydraulic cylinder rebuilding. How to purge the air out? #1
TimP82
2003 Ironhorse 284
Good Morning everyone.
I have to rebuild the curl cylinders on my fel soon. I have the rebuild kit and now I just need the time to get started. I have a question during re-assembly. Should I assemble it with as much hydraulic oil inside as I can get without making a mess, or should I just use enough oil for the assembly? I guess what I'm asking is, once I re-connect the rebuilt cylinders to the tractor, how do I get all of the air out?
Thanks all in advance!
-Tim
   / Hydraulic cylinder rebuilding. How to purge the air out? #2
Assemble the cylinder on the loader dry, then to purge, you simple cycle the cylinders in and out a couple times.
It will take a while to fill up the cylinder before it starts moving.
Once you see that the cylinders are moving smoothly and not jumping due to the air inside, you're good to go. Check the hydraulic level after as it will get lower.
   / Hydraulic cylinder rebuilding. How to purge the air out? #4
I concur. :)
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
2012 RAM 5500 (A52472)
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
Informational Lot - Financing (A53472)
Informational Lot...
