2015 HST glow plugs burning out
   / 2015 HST glow plugs burning out #11
What would be wrong with a dash mounted pushbutton, running say a five dollar starter relay and running the glow plugs that way. Who needs a two hundred dollar controller? If I had a simple switch like that, the plugs on GMC duramax wouldn't have failed one by one either!
   / 2015 HST glow plugs burning out #12
It could be argued that is an improvement. Following heavy amp draw of glow plugs and starter,alternator charges at max capacity to recharge battery. High amp charging effect's alt life more than lower charging. Over time as alternator output decrease's,the tractor must run longer to bring battery to full charge and we know where that eventually leads. Glow plug life also depend's on hours they are on. The only reason I've been given for not running plugs after engine start's is to prevent smoke. IDK if anything negative happen's to engine as result of smoke. If so,you can always hold the switch on a while longer after engine fires.
Good idea Toys but I should warn you that here at TBN, one single aw shucks wipe's out ten attaboys. :laughing:
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2020 Kia Sportage LX SUV (A50324)
2020 Kia Sportage...
1975 Chevy C60 Grain Truck (A50514)
1975 Chevy C60...
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A51244)
UNUSED FUTURE MINI...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
