Reading Hydraulic/tranny fluid levels
   / Reading Hydraulic/tranny fluid levels #1
Chaos USMC
South Central Pennsylvania
TYM T503, 1962 Case 530 Case-a-matic
Because of the color (or lack thereof) of the hydraulic/transmission fluid in my tractor (absolutely clear) I have a hard time telling where the exact level of the fluid is on the dipsticks. I have to try to read it numerous times before I am confident I am reading it correctly.
Is there any kind of "dye", etc. that can be added that gives the fluid a darker color so that levels can be more apparent on the dipsticks? Or, perhaps there is an aftermarket dipstick that is "etched" that allows for more distinct level indications...
Thanks.
   / Reading Hydraulic/tranny fluid levels #3
Maybe pull the stick and lay it on a paper towel?
Gentleman, thank you your feedback, appreciate your efforts... Safe day.
   / Reading Hydraulic/tranny fluid levels #5
If it's a flat dipstick, you can also drill 2-3 1/8" holes in it, one at the add mark, one at the full mark and perhaps one midway between the two.
Aaron Z
   / Reading Hydraulic/tranny fluid levels #6
Hello Chaos USMC, I do a variation on ovrszd, I lay the dipstick on my glove palm,then move the dipsick sideways, the oil shows up nicely, even in poor light.
Hello redman and aczlan, thankyou for commenting.
My fluid is absolutely clear/translucent on the stick. (a good problem to have, right...) Not sure drilling the holes would make a big difference. I was thinking of using a Dremmel to put some cross hatching on the stick for possibly better fluid adhesion/detail. Ericm's suggestion for the John Deere dye look's feasible but multiple bottles of the dye at roughly $13/bottle would be required.
I do like the glove "trick". It will also give me a good excuse to get some new gloves, way to many holes in the pair I have now!
   / Reading Hydraulic/tranny fluid levels #8
You can use a paper towel instead of the glove.
Some dipsticks come with tiny holes from the factory. I have seen that on engine oil dipsticks. The oil fills in the holes due to surface tension, making a visible indicator.
There are other sources of oil dye than Deere. They may be cheaper.
   / Reading Hydraulic/tranny fluid levels #9
I use a bunn coffee maker's clean out spring.
   / Reading Hydraulic/tranny fluid levels #10
I simply tilt the dipstick until the light reflects the oil. I just offered the paper towel solution as an alternative. :)
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A54607)
2019 HYUNDAI...
42013 (A51691)
42013 (A51691)
PENDING SELLER CONFIRMATIONS (A54607)
PENDING SELLER...
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
