Hydraulics, try pumping out the old fluid and air
   / Hydraulics, try pumping out the old fluid and air #1
Little1710
ford/1710
I have learned so much on this forum I thought I'd contribute. I have an 87 Ford 1710 that had milky fluid and the 3 pnt had no lift like there was a blockage. I think moisture just built up causing the milk or maybe a leak around the shift boots. None the less it was fluid change time. After draining at the 4 sump locations I left it open all night. The next day I replaced plugs and removed the diverting block and pulled the relief out for a complete clean. Then I loosened lines running from the diverting block to the back and allowed frothy fluid to drain out. I noticed a banjo bolt holding the filter housing and pulled the bolt out to find a piece of what appears to be some type of heavy paper towel or filter membrane. As I removed it I was wondering if previous owner swabed out a fitting and some of the rag tore off. I'm thinking that was the blockage issue starving the pump. Replaced the filter and refilled reservoir. I left the front of the diverting block seperated from the pipe coming from the pump and placed a bucket under it. I ran the engine until I saw the last of the old oil and the beginning of the new. Then I reconnected that line and loosened the rear banjo bolt and did the same to flush out that line as well. Puppy runs like a new one. Probably didn't have to disconnect for first bleed at the diverting block but I already had it loosen because I cleaned it. Got rid of old oil and air locks at the same time. Just my 2 cents. Keep them old rigs running y'all, they don't make em like they used to.
Forgot to post relief in division block.
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
HARDEE D-3-816 LOT NUMBER 155 (A53084)
HARDEE D-3-816 LOT...
SHOULE RM8080 LOT NUMBER 129 (A53084)
SHOULE RM8080 LOT...
2023 FORD F-250 SUPER DUTY (A52472)
2023 FORD F-250...
A1 MIST SPRAYERS RESOURCES TX3PT LOT NUMBER 85 (A53084)
A1 MIST SPRAYERS...
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
