3 cylinder vs 4 cylinder
   / 3 cylinder vs 4 cylinder #31
Not all Perkins are created equal, my AD3-152 is a very good engine, starts easy in below -15c without any heating or glow plugs and are quick and very economical, but not all engines series are so good, and it's British and made in tens of millions scale. Only wished it had wet liners and not dry but not a big issue.
I have over 6500 hours on my 135 and it still runs strong!
   / 3 cylinder vs 4 cylinder #32
A 4 cylinder vs 3 cylinder is probably the last factor I care about when looking for a machine. I’d rate the seat covering material as a higher priority.
   / 3 cylinder vs 4 cylinder #33
My Kubota L2900 was 30 hp three cylinder, very reliable machine. My current machine is a Deere 4720 is 66 hp 4 cylinder, I really didn't notice any difference between the two as far as noise or vibration. My JLG boom lift has a three cylinder Duetz diesel, great engine.
   / 3 cylinder vs 4 cylinder #34
Good thing the Perkins is a Diesel, otherwise being British, if it required electric ignition, it would never start.
My Dad visited me today in his 5 cyl Diesel Sprinter. Just about surprised me, that thing is so quite.
   / 3 cylinder vs 4 cylinder #35
Isn't Perkins now owned by CAT?
   / 3 cylinder vs 4 cylinder #36
One of my MF245s is right in there with you. 6000 something hours and running good and smooth. However, my smoothest engine is a 5 cylinder Kubota direct injection from the late 90s.
   / 3 cylinder vs 4 cylinder #37
I think I heard one of those Kubota five cylinder tractors. I thought, it made our 70 PTO hp JD 6200 sound like a pile of junk. But what of torque? That 5 cylinder is also very fuel efficient, whereas our JD has a drinking problem!
   / 3 cylinder vs 4 cylinder #38
We all remember the old adage, that "there's no replacement for cubic inches"....well, that's where the turbo charger (TB) comes in...a 3 cyl with TB may put out as much HP as a non TB 4 cly, and I'm pretty sure that 3 cly engines are "cheaper" for the manf. to build....I'd rather have a non TB 4 cyl putting out 60hp than a 3 cly putting out the same hp. For one thing, the 4 cly, with normal maintenance will most likely outlast the TB 3cly...also no cool down on the 4 cly. engine....just my 2 cents... BobG in VA
Agreed. A smaller cubic inch engine will likely need to be ran at a higher rpm to achieve its hp than a larger displacement one will. More displacement also equals more torque. I would rather be able to work with one that didnt have to be run at its highest rpm all the time to make its working hp.
   / 3 cylinder vs 4 cylinder #39
Why do you need rpm? A modern diesel with turbo pulls on low rpm, old sluggish,non turbos are total gutless without RPM, of course you kan add volum, cylinders and weigh ending up with a ineffective design that is very expensive and give you zero value.
   / 3 cylinder vs 4 cylinder #40
Our sailboat had a Westerbeke 4-154 diesel (Perkins clone) normally aspirated, we were thinking about repowering with a turbo Yanmar of about the same displacement. The Yanmar would have been maybe 25% more fuel efficient than the old Westerbeke. This would have been a significant improvement since we only carried 75 gallons of fuel (we were blue water sailors.)
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
202476 (A54757)
202476 (A54757)
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
