3 cylinder vs 4 cylinder
   / 3 cylinder vs 4 cylinder #61
Could use the same discussion about 4 cylinder vs. 5 cylinder cars. Lots of smooth 5 cylinder ones out there.
By same token, arguments could be made about going down from 3 to 2 cylinders, e.g. like the BX 1500. Don't think it was particularly different in vibration than any other.
Re fuel consumption: gas engines with carbs will use 50% more fuel than non turbo diesel engines. We engineers had both kinds of vehicles back in the 80s. Our (mostly) cars with gas engines with carbs had 30 ton-mpg average. Average on our diesels was 45 ton-mpg. This is the mpg that a 1 ton vehicle would get. Could easily prorate by vehicle weight, except it didn't work for a diesel big Ford pickup. It used less fuel by weight.
Prorate tractor fuel usage by hp.
Ralph
   / 3 cylinder vs 4 cylinder #62
I know most if not all of the 30 - 40 HP compacts either have a 3 or 4 cylinder. Wouldn't the 4 cylinder be a smoother engine by default? If you had a choice between a 3 or 4 cylinder, which would you choose?
[video]https://en.wikipedia.org/wiki/Engine_balance[/video]
Engine vibration is dependent on much more than the number of cylinders. Cylinder orientation, crankshaft throw alignment and any other rotating component of the engine is involved.
   / 3 cylinder vs 4 cylinder #63
You can add crankshaft balancing counterweights to that.
I drive a Mitsubishi 3 cylinder tractor and as far as can say I never have noticed even the simplest undesirable vibration.
Now I once was near a 2 cylinder Kubota compact tractor and man did that thing shake rattle and roll.
   / 3 cylinder vs 4 cylinder #64
My Steiner 430 with the little 3 cyl Kubota is a rough little engine, especially at IDLE. The little 4 cyl Kubota Engine in my little Kubota Wheel Loader is also a bit rough at Idle. I bet, but I don't know, that a Kubota 5 cyl is as smooth as silk at Idle. Might even make a sweet generator running at 1200.
2019 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A55973)
2015 Peterbilt 348...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A56858)
2008 Ford E-350...
Sundowner Rancher Express 20FT Livestock Trailer (A56435)
Sundowner Rancher...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
