What did you find was the problem with this ?? Did you solve it??
Unfortunately, I have not solved the problem, but here is what I know;
The charge pressure was on the low end of normal (reading a gauge installed in the test port) I cranked the posi-power relief valve all the way out and now the charge pressure is on the high end of the spec. This made a slight but noticeable improvement in the control response.
I changed the filter on the charge system....this made no improvement.
The control response "sluggishness" ranges from a minor annoyance when the oil is warm (+60 degrees f) to rendering the machine nearly unusable in very cold temperatures (-30 degrees f)
The slow response is limited to the drive controls, the lift and aux controls are unaffected.
The hydraulic quick-couple is also noticeably slower in cold weather...Both the feed out to the drive joystick and the quick coupler cylinder feed come off the same side of the pilot generation block, making me suspect that there is some type of obstruction in the pilot generation block. This could be foreign material, or perhaps the drive control safety solenoid is not opening completely.
My next move may be to pull this valve, and switch it with one of the others to see if there is an improvement. I may also try disconnecting the feed line at the joystick to see what I get for a pressure reading there.
BTW..it is MUCH easier to work on the pilot gen block by tilting the cab and pulling the footwell, but you will still need access from below..
It would be nice to have a schematic diagram of the pilot generation block, but so far I have been unable to find this...
Any help or experiences that others may have would be welcome!
