stuck front axle Fill Plug on Deere 2955
   / stuck front axle Fill Plug on Deere 2955 #1
gtrgarden1
What ideas do you have for loosening the Fill Plug on the front axle of a Deere 2955 tractor?
The plug is not stripped. A breaker bar fits tight in the plug, but no amount of heaving I have done is breaking the plug loose.
I sprayed some WD-40 around the plug yesterday to see if it might penetrate to help loosen the thread [I haven't checked back on that yet]. But, since the plug is on the side of the axle, I'm not sure if any penetrant would have much opportunity to move down into the threads.
I suppose heat would also be an option.
   / stuck front axle Fill Plug on Deere 2955 #2
I don't know how much work space you have but sometimes an impact wrench can loosen frozen threads. Sometimes you can break a frozen fastener by tightening before loosening but I don't think that would work well with a tapered thread plug.
   / stuck front axle Fill Plug on Deere 2955 #3
Have you attempted to hit plug with a large hammer? If large hammer doesn't loosen plug my next choice would be an acetylene torch.
   / stuck front axle Fill Plug on Deere 2955 #4
Saw this on another forum:
Doug in SW IA
   / stuck front axle Fill Plug on Deere 2955 #5
I was going to recommend the same exact thing. Impact wrench. Try tightening. Sometimes that breaks away from something holding it from turning in the reverse/out direction.
I think I would drill it out before resorting to a torch. If you drill put grease on the drill to collect chips and clean and regrease often. Good luck!
   / stuck front axle Fill Plug on Deere 2955 #6
impact. tighten then loosen.
   / stuck front axle Fill Plug on Deere 2955 #7
Wd-40 is about worthless for a penitrant. Hit it with a hammer a few times, the shock should loosen it up. If not you may need to heat it a bit.
2018 Genie GTH-636 (A50123)
2018 Genie GTH-636...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
2024 Deere 317G (A50123)
2024 Deere 317G...
Case Maxxum 140 (A50120)
Case Maxxum 140...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2009 Peterbilt 335 Cab and Chassis Truck (A51692)
2009 Peterbilt 335...
