2011 MF1652L Platform 572 hours - electrical issue - ahhhh! HELP!!!
   / 2011 MF1652L Platform 572 hours - electrical issue - ahhhh! HELP!!! #1
MRICH
Powhatan, VA
Massey Ferguson 1652
No power to instrument panel, No response from ignition in any key position. Battery Drain.
Headlights and turn signals work. Emergency flashers do not.
What I have tested so far:
Recharged Battery. Had Battery load tested at Advanced Auto Parts. Meets specifications. This is the original battery.
Checked all fuses in fuse box. No visual issues. Continuity test performed. All working.
Tested Ignition switch - passed. Stupidly purchased new ignition switch - no change.
Tested blue (power) lead to ignition splice coupler - power reading of 12.4 V.
Tested power to Starter. Full power found.
Tested all relays. All working. Checked for click and resistance across actuated circuit.
Today tried to test the instrument panel by disconnecting battery. Used known strong battery to supply power at #5 fuse connection (instrument panel and ECU)-nothing.
Could a malfunctioning ECU create these issues?
Any other suggestions?
Mark
   / 2011 MF1652L Platform 572 hours - electrical issue - ahhhh! HELP!!! #2
Try to track down an electrical schematic for your tractor to get an idea of what feeds what. A malfunctioning ECU probably could cause your problems but you don't want to buy one if you don't need one - kind of like the ignition switch you bought.
   / 2011 MF1652L Platform 572 hours - electrical issue - ahhhh! HELP!!! #3
Maybe pull the instrument cluster and check the wiring; mice may have chewed something
   / 2011 MF1652L Platform 572 hours - electrical issue - ahhhh! HELP!!! #4
Checked all fuses in fuse box. No visual issues. Continuity test performed. All working. Was there power on the fuses?
Tested Ignition switch - passed. Stupidly purchased new ignition switch - no change. Tested all positions like fuel/starter solenoids and GPs? Actual 12v flowing?
Tested blue (power) lead to ignition splice coupler - power reading of 12.4 V. Blue power to IGN????
Tested power to Starter. Full power found. The main big cable or solenoid?
Tested all relays. All working. Checked for click and resistance across actuated circuit. Check that 12v flows after click?
   / 2011 MF1652L Platform 572 hours - electrical issue - ahhhh! HELP!!! #5
Does your tractor have a fusible link or main fuse in a different location? Also, supplying power directly into a fuse box without knowing the schematic may be dangerous to some expensive components.
There is power to the fuses.
I tested all positions on the ignition switch for continuity using multi meter. No power flowing.
The Blue wire is the hot wire on the four way connector. It changes to red on the switch side.
Power on the big main cable.
No voltage on relays.
We ran a power draw test and found no parasitic draw.
We jumpered the tractor side of the ignition switch harness but still no power to the instrument panel.
I have an electric schematic.
I have the schematic. I have color coded much of the wiring for easier reading. I have labeled all of the identified components also.
Can the ECU be tested?
2021 Ford Mustang Mach-E AWD SUV (A55853)
2021 Ford Mustang...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
FRONTIER 3 PT HAYSPEAR (A57192)
FRONTIER 3 PT...
2002 Isuzu NPR-HD Truck, VIN # JALC4B14727002397 (A56858)
2002 Isuzu NPR-HD...
UNUSED PABREAK BC352 - 72" HYD BRUSH CUTTER (A57193)
UNUSED PABREAK...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
