Seafoam
   / Seafoam #31
Snake ain't even listed on the list of ingredients!
   / Seafoam #32
Call it what you want, it works for me for its intended purpose.
   / Seafoam #33
It's worked for me a few times actually, I'll take another bottle of that snake oil, thank you.
   / Seafoam #34
Seafoam is not a be-all-end-all, but it is a great tool to have available. It's worked for me several times, cleaning small engine carbs and smoothing out rough engines. There are times when nothing beats pulling the carb to thoroughly clean it or replace it, but a heavy dose of SF works many times. That saves me time and money. :thumbsup:
   / Seafoam #35
It does work - I cant believe somebody hasn't outlawed it claiming that it is bad for the environment or something
   / Seafoam #36
Ah heck it's done for now, the super cops will be all over it :censored:
   / Seafoam #37
It really would help the environment if all fuel systems were clogged. :)
Bruce
   / Seafoam #38
I use it and MMO from time to time, maybe every third or fourth tank, but I can't honestly say I've ever noticed a difference either way.
   / Seafoam #39
We keep a box of sea foam here for all our seasonal or occasional use engine fuel tanks. In my experience, its the best fuel stabilizer made. Used that stabile brand a few times and had poor luck. No more.
   / Seafoam #40
I tried Mechanic in a Bottle and Sea-foam on my 4 year old Sears riding mower this past summer trying to get the motor to run smooth, well it worked at first then went back into surging again and when I put the mower away this fall the motor was still surging, I'll take the carb off next spring for a cleaning and see if I can make it run worse. Sears riding mower P-1 - YouTube
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55302)
2017 Rogator...
2014 Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
2014 Peterbilt...
2016 INTERNATIONAL MA035 (A53843)
2016 INTERNATIONAL...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2017 FORD F550 XL SUPER DUTY BUCKET TRUCK (A51406)
2017 FORD F550 XL...
