1962 Italian tracked tractor restoration
   / 1962 Italian tracked tractor restoration #1
ptsg
Super Member
Portugal
Branson F36Rn - Agria 8900D
I was going through some old pictures and decided to make a slideshow video about the restoration of the 1962 Toselli 226 I had back in 2015.
I got this machine basically for free. I traded a very old and small 2wd tractor with 13HP for this one.
This tractor comes with a 28 HP air cooled VM engine. It's a very compact tractor being 2.5 meters (98") long and 1 meter (40") wide, weighting around 1700 Kg (3800 lbs).
It does have a standard cat 1 3 pt hitch, a two speed PTO and it uses a 8x2 gearbox for the main transmission.
Toselli company was bought by Agrifull back in the 70's and the Agrifull was bought by Fiat in the 80's I believe.
As you can see from the pictures, I got it in a very sad shape and had a few problems:
- Someone had put a undersized exhaust pipe all the way to the rear which choked the engine pretty bad and was full of carbon inside of the manifold. The exhaust was actually the first part I did for the tractor.
- The right track would disengage or brake to steer the tractor, turned out, that other than the clutches and brake bands were full of oil, it also had a pin missing on the linkage that would apply the brake band.
- Sometime in it's life, it was dropped from a truck and broke a piece of the rear transmission housing casting and also cracked one of the final drives. Booth were easily fixed by welding with some Nickel rods.
- The engine, besides being aircooled, also requires some basic maintenance on the cooling system, which was never done. The air duct had a nest inside and the fins on the heads were completely blocked with all kinds of nasty stuff. Fortunately, the engine was in good shape and ran very good.
- Part of the 3 point was missing, so I just remake the entire linkage.
- The steering levers will do two functions at the same time. Will disengage the clutch for each track and apply the brake band accordingly. Needless to say, it was way out of adjustment.
- The PTO had one gear missing a bunch of teeth and the rest all cracked. Had to get a new gear made for it.
Unfortunately I've never finished the tractor 100%. The hood and grille still needed to be prepped and painted as it was full of dents and I never mounted the headlights as I wanted to fixed some stuff on it but never did.
Somewhere in the middle of the restoration, I found the big brother of this machine for around 800$. A Toselli 340, a 39 HP 3 cylinder machine. Almost in the same state of the 226 but the mechanical were in better shape. However, the engine was lacking lots of power. Probably could use a rebuild.
In the end, I made a bulldozer blade for the 226 but then swapped it to the 340 and sold it. While I also traded the 226 and a Kubota B7000 with an homemade loader for the new Branson. Sadly, the 226 is sitting outside in the dealer with the paint completely faded and getting rust all over the place.
   / 1962 Italian tracked tractor restoration #3
Very cool. I skimmed through your video to the very end where it shows you tilling up that orchard and was very impressed. Looks like one of those machines that would be fun to have, but torture to operate!!!
   / 1962 Italian tracked tractor restoration #4
I agree with Eddie!!!
Thanks for posting. I'm always interested in the background in pics and videos. Good stuff!!!
   / 1962 Italian tracked tractor restoration #5
Do you have any info on parts for VM engines?? --- I have a VM 80hp air cooled diesel engine on a wood chipper and cant find parts around here for it. Everybody says they never heard of a VM motor!
Neat looking machines. :thumbsup:
Thank you!
Thank you! Actually it's not too bad to drive but it's indeed really fun to have and play with.
The way this tractor is setup is:
- Left pedal - Engine Clutch
- Right pedal - Brakes ( both tracks)
- Left lever - Left brake and steering clutch
- Right lever - Right brake and steering clutch
It's not as demanding as an actual bulldozer with the hand clutch for the engine and separate controls for steering clutches and brakes.
Thank you!
I do know a couple Italian companies making replacement parts for these engines but I do need to research that. Last time I checked that was in 2015.
I believe these guys can get pretty much every part for any VM engine. They have the catalogs available. It's just a matter of finding your engine there.
Home - Finimpianti
   / 1962 Italian tracked tractor restoration #7
Good job
   / 1962 Italian tracked tractor restoration #9
View attachment 629554View attachment 629555
No feeling like cranking a left turn on old orchard Cat D2 and watching the right track head off straight. Sat there a minute to choose words because a bunch of kids were watching. As a temp (15+ years ago) fix added 1" blocks to ram on each side that controls track adjustment. Did the same on another old Cat D6 after a track carrier bearing let loose. At the time they both did fine and haven't used either for at least 15 years. These 2 Caterpillars have pony motors and are from the 1940s. Now they sit under roof where cattle/horse feeding was done and accumulate mice, dust, some rain and the brown air from San Jose about 10 miles NW of ranch.
Thank you for your thought on hydraulic pipe that splits power/fluid on the newest ranch tractor, 78 Case 580CK extendahoe. I have the tools to spread ends for compression fittings and it should work great.
Those old CATs are awesome. I've had my eyes peeled for a D2 but the prices... That's hard to swallow for what's essentially an hobby.
Keep those CATs in running condition and the value of those will only go up with age.
No need to spread the ends for the compression fittings. I'll add some more info on your thread so it's stays in the same place.
2022 Heli Forklift (A51573)
2022 Heli Forklift...
New/Unused Agrotk Horizontal Band Sawmill (A51573)
New/Unused Agrotk...
UNUSED RAYTREE RABC44-44" ARTICULATING BRUSH CUTTE (A51248)
UNUSED RAYTREE...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53472)
NEW 2025 Load...
