MF1734e, loader main valve issue
   / MF1734e, loader main valve issue #1
jcmaurice6
Sherbrooke, Quebec
Massey Ferguson 1734E
The main valve has either condensate or water has infiltrate in the casing extension at the spool end (item 6 on the drawing). After disassemble and clean all valve part, better seal the casing. I put everything back but now, the floating mode is not latching! At the end of the spool, inside the case, there is a spring with some special washer.
How the latching system work?
What a should be careful with when I put everything back?
View attachment VALVE ASSEMBLY - JOYSTICK CONTROLLED.pdf
   / MF1734e, loader main valve issue #3
Float mode latch has never worked very well on mine. Sorta holds but will pop out pretty easy.
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
1985 International X Con Semi (A50514)
1985 International...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
