How to know when to change front tires on 4WD tractor?
   / How to know when to change front tires on 4WD tractor? #11
You probably already know it but fronts are always 5% oversized to compensate for wear hence they do wear faster as well as being smaller.
When they approach baldness they probably are even with rears as to traction or contact.
Loss of traction will be your answer, that or when cords start showing.
Actually they are setup to "pull" so you can turn when in 4wd.
   / How to know when to change front tires on 4WD tractor? #12
My old L2550 with R1 tires has plenty of traction with existing tread, but the rubber is highly checked. Is checking not a concern here, too?
Not really, my fronts have cracked up a bit even though the tractor is undercover 99.9% of the time. The only time I really think about something bad happening with a blow out is going full speed down the road with a wagon behind me. That said the tires on the hay wagon are nearly transparent with all the checking but they don't seem to mind a few 1/2 mile trips a year at 12 mph... I'm going to run them till they wear out or leak too much anyways.
Well, I had my replacement decision made for me, when a J-hook, on a chain, hanging from my brush guard got knocked off while working. It got hung under the RF tire and pulled into the tire. It left a gaping, irreparable hole. I opted for Carlisle Guard Dog R4 tires, as reviews I read during the search process stated that they would last longer and were more durable than cheaper tires. Just got them installed and they look great. The tread looks very deep. It looks like these 10-16.5 tires are for a skid steer. Only time will tell as to how long they will last.
Changing in and out of 4wd is a breeze now.
Chris
   / How to know when to change front tires on 4WD tractor? #14
Pertaining to tire wear, do you guys air your tires to how they contact the ground or just a couple under max? I have noticed my father in law R4 tires seem to only contact mostly the center of the tires on the gravel with the recommended air pressure. Seems like they are wearing more in the middle than anywhere else on the tire. I like a uniform wear pattern but is that just nature of the beast? The R1 tires I have seen on our family tractors seem to wear pretty even but we also air them on the lighter side for more ground contact.
   / How to know when to change front tires on 4WD tractor? #15
I air mine based on ground contact. On any tire, car or tractor, if its wearing heavy in the center, its overinflated for the load. It puffs up like a round inner tube & only the center is making good contact with the ground. Deflating it a bit will give it a more square profile, better traction & even wear.
   / How to know when to change front tires on 4WD tractor? #16
Test is have it in 4wd, on a hard surface, running in a medium gear at a medium RPM and take it out of gear. If it slows down rapidly, the axles are at odds. Or on that hard surface, low gear and slow, turn hard to one limit and watch the front tire to surface contact. If leaving rubber, tread marks or obvious traction errors in either direction...being pushed, or pulling, time to change.
However, if you stay out of 4wd except on soft surfaces not that big of a deal. I'm not worried about the tire surviving the experience. My concern is that the front axle is a supplementary drive source and not made to take the brunt of the traction. No doubt that front axle breaks posted herein and elsewhere on the web attest to excessive front axle stress. My 2c and the way I conduct myself. Some of the OOPs pictures attest to that analogy.
   / How to know when to change front tires on 4WD tractor? #17
When they bind up the gears for the last time before they break something.... Its time to replace the tires.
   / How to know when to change front tires on 4WD tractor? #18
I'm always in 2WD. Unless I got to those known spots on the property. Then it's 4WD BEFORE I reach any of those spots. The R-1's on my first tractor were in great shape after 27 years. Use the tractor wisely and keep those tires out of the sun when parked.
   / How to know when to change front tires on 4WD tractor? #19
That is my pretty much my operating style except in winter when 4wd is essential around my steep sometimes very sloppy land.
   / How to know when to change front tires on 4WD tractor? #20
That's what I like about the Branson 4wd tractors. No need to use the brakes to turn like I have to in the Fords with 2wd.
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
UNUSED FUTURE BK56 56" HYD BACKHOE DIGGING ARM (A58376)
UNUSED FUTURE BK56...
Unused IRTPL 10,000lb Two Post Car Lift (A55272)
Unused IRTPL...
MAHINDRA 3650P TRACTOR (A58375)
MAHINDRA 3650P...
300 GALLON FUEL TANK (A58375)
300 GALLON FUEL...
2010 Cadillac SRX SUV (A56859)
2010 Cadillac SRX...
