ck3510se white exhaust smoke when cold, only started after last oil change
   / ck3510se white exhaust smoke when cold, only started after last oil change #1
NYCheese
Near Binghamton NY
Kioti CK3510se hst TLB
My first 2 oil changes were done using a Cub Cadet branded diesel oil (dealer is also a Cub Cadet dealer, and he said it exceeded Kioti's requirements).
Most recent oil change I had to switch, because he was out of stock, and said it was going to be a while before he got more. He recommended the Rotella T4, and after doing some research online, that's what I went with.
I've put about 30hrs on since then, and I've noticed that when the tractor is cold, I'm getting a fair bit of white exhaust (that smells like unburnt fuel), that I never had last winter with the other oil. It goes away when the engine warms up, so it seems pretty normal to me...just wondering if I should be concerned at all.
   / ck3510se white exhaust smoke when cold, only started after last oil change #2
I believe a small amount of white smoke indicates unburnt fuel when the engine is cold and is perfectly normal. I don't know what constitutes "a fair bit" but if it disappears when the engine warms your should be fine.
   / ck3510se white exhaust smoke when cold, only started after last oil change #3
condensation steaming off is also a common cold startup white smoke signature. Also normal.
Thanks for confirming normal for me. I said "fair bit", because it's definitely less than what I would call "a lot", but it's slightly more than I would call "a little". It does go away entirely once the engine is up to temp.
It definitely has some unburnt fuel in it, you can smell it clearly. I was pretty sure it's normal for cold weather....just wanted to confirm, since I did swap oil brands.
   / ck3510se white exhaust smoke when cold, only started after last oil change #6
All diesel's 'huff' a bit when cold, especially when it's around or below freezing. Nature of the engine.
   / ck3510se white exhaust smoke when cold, only started after last oil change #7
I suspect the ambient air temperature is lower or the cetane rating of your fuel is lower than what you used last winter.
Lube oil won’t cause white smoke.
JMR 44" Mini Bucket (A50121)
JMR 44" Mini...
KMC 5610 (A53084)
KMC 5610 (A53084)
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
Cub Cadet 7254 Compact Tractor (RUNS) (A50774)
Cub Cadet 7254...
2013 Infiniti M37 Sedan (A50324)
2013 Infiniti M37...
John Deere 445 Lawnmower (RUNS) (A50774)
John Deere 445...
